Intel One API
needyourhelp
Hello. I just installed both Intel One API HPC and Base Toolkit. But when I open Visual Studio ----> About Microsoft Visual Studio----> I don't see all Intel related products (just 2 of them appear), as shown in the screenshot attached. It seems like the Intel API were not fully integrated within Visual Studio.
     Thank you in advance for your help
jimdempseyatthecove
Have you installed:
Visual C++ 2022 00482-90000-00000-AA203
Microsoft Visual C++ 2022
The oneAPI tools use the MS VS C runtime libraries and linker. This must be present in MS VS prior to installation of oneAPI toolkits.
Also, oneAPI installation order is: Base Toolkit, then HPC Toolkit
Jim Dempsey
Steve_Lionel
needyourhelp
Thank you for your help. Apparently the 2025 versions do not support the fortran compilers, so I eventually had to install the 2024 versions for both Intel OneAPI Base Toolkit and Intel OneAPI HPC Toolkit. And It worked.
andrew_4619
" Apparently the 2025 versions do not support the fortran compilers"- The OneAPI 2025 versions support IFX Fortran not IFORT and IFX  Fortran
