Intel OneAPI Base Toolkit-Reg
DSChand
I am a basic learner and a retired Senior citizen interested in Fortran,Assembly languages.
In 1980's developed some software with MS-DOS applications of Fortran,Assembly languages.
Now again I am interested to develop some simple astronomy applications with the above mentioned languages.
Regarding Intel OneAPI standalone compiler installation time facing the below troubles:
While installing Intel OneAPI Base toolkit v.2025.3,OneAPI HPC toolkit v.2025.3,OneAPI CPP Essentials v.2025.3,Fortran Essentials v.2025.3 below error occurs:
Critical Prerequisites
Another program is being installed
Wait until that installation is complete,and then try installing this software again.
Software installer v.4.4.5.2352
Quit
I am using 64 Bit,Windows 11,Acer Aspire Lite AMD RYZEN 5000 series, AMD Graphics,Nahimic steel series Laptop to install and run Intel Fortran Compiler 2025.3.
Using Microsoft Visual Studio 2026.
Please help and guide me to install the above mentioned compiler without any troubles.
2/3 times tried, but everytime the same error occurs repeatedly.
Waiting for your valuable help,guidance,suggestion at the earliest.
with Regards
D.Sundar Chand
Hyderabad,
India.
[email protected]
JohnNichols
Honored Contributor I
Clean out all oneapi and visual studio
reboot
USE VS 2022 as 2026 is new and you need the latest update so stick to 2022
Install using
Then install oneapi base kit and then HPC and it should work.
Steve_Lionel
Posting in multiple threads is annoying - please don't do that. At least in this one you said what the error was.
Reboot Windows and try again.
DSChand
Sorry for the trouble.Thanks for your fast reply.That also tried 3 times, but failed. That is why I am posting.
Is there any solution for my problem?
Please try to help/guida/advice me.
with regards
JohnNichols
reboot
Install using
DSChand
Thanks for your fast reply and guidance.
Only Intel-oneapi-basetoolkit is installed, but other Intel-oneapi-hpc-toolkit, Intel-oneapi-cpp essentials,Intel-oneapi-fortran essentials are not installed. I don't know the reason behind it.
Please help/guide me if possible at the earliest.
Waiting for your guidance,help,suggestion at the earliest.
with regards,
DSChand
Giving error as below:
Another installation going on...
After watching there is no other programs installing.
From the last one month I am trying to stop the above mentioned error, but is utter failure.
Because of this error all the other installations are not working.
Please guide/help me how to stop that error.
with  kind regards
JohnNichols
Download revo unistaller and let it see what is on your computer, if you reboot there should not be installers, or something is jammed like a graphics driver is stuck
What sort of computer and the OS?
DSChand
Thanks for your fast and kind reply.
Acer Aspire Lite Al 15-14 AMD RYZEN 5000 Series,AMD RADEON,Nahimic steelseries Laptop.
OS :windos 11.
This is for your kind information and ready reference.
I will try and revert you the result.
DSChand
Waiting for your kind guidance,help,suggestion at the earliest.
with regards,
