29559 Discussions
Intel Parallel Studio XE 2015 Update 1 Composer Edition - VS 2012 Integration failed
Smiljan_T_
- I have installed VS 2012 Professional
And after that I did Install w_fcompxe_2015.1.148.exe (Intel Parallel Studio XE 2015 Composer Edition)
I have checked and confirmed the integration while installing, This appears in VS 2012 (Help-> About), there is no Intel Fortran Compiler, nor in Options->Tools nor in Create New Projects.
Microsoft Visual Studio Professional 2012
Version 11.0.61030.00 Update 4
Microsoft .NET Framework
Version 4.5.51209
Installed Version: Professional
LightSwitch for Visual Studio 2012   04938-004-0033001-02869
Microsoft LightSwitch for Visual Studio 2012
Team Explorer for Visual Studio 2012   04938-004-0033001-02869
Microsoft Team Explorer for Visual Studio 2012
Visual Basic 2012   04938-004-0033001-02869
Microsoft Visual Basic 2012
Visual C# 2012   04938-004-0033001-02869
Microsoft Visual C# 2012
Visual C++ 2012   04938-004-0033001-02869
Microsoft Visual C++ 2012
Visual F# 2012   04938-004-0033001-02869
Microsoft Visual F# 2012
Visual Studio 2012 Code Analysis Spell Checker   04938-004-0033001-02869
Microsoft® Visual Studio® 2012 Code Analysis Spell Checker
Portions of International CorrectSpell™ spelling correction system © 1993 by Lernout & Hauspie Speech Products N.V. All rights reserved.
The American Heritage® Dictionary of the English Language, Third Edition Copyright © 1992 Houghton Mifflin Company. Electronic version licensed from Lernout & Hauspie Speech Products N.V. All rights reserved.
Visual Studio 2012 SharePoint Developer Tools   04938-004-0033001-02869
Microsoft Visual Studio 2012 SharePoint Developer Tools
PreEmptive Analytics Visualizer   1.0
Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
SQL Server Data Tools   11.1.20828.01
Microsoft SQL Server Data Tools
When I check in the C:\Program Files (x86)\Microsoft Visual Studio 11.0, there is:
  • Blend
  • Common7
  • DIA SDK
  • FSharp
  • ImportProjects
  • Intel Fortran
  • JavaScript
  • VC#
  • VC
  • VB
The Intel Composer XE 2015 is installed (C:\Program Files (x86)\Intel).
Does any know what could be the problem? Thanks in advance if somebody knows what could be the reason, while the integration failed. I did try also:
https://software.intel.com/en-us/articles/troubleshooting-fortran-integration-issues-with-visual-studio
Visual Studio 2012
Close Visual Studio and type the following commands:
cd %VS110COMNTOOLS%
cd ..\..\Intel Fortran\VFPackages
integrate.bat "%VS110COMNTOOLS%" /u
It doesn't work.
Kind regards,
STU
Do you get any error messages when you try the commands in the article? We now have Update 3 available - I suggest you uninstall Update 1 and install Update 3.
Smiljan_T_
Hi Steve,
Thanks for the fast reply. I do not get any error messages when I try the commands in the article, what I get is "completed".
What I also tried is:
  • installed the update 3 and nothing changed.
  • deinstalled Visual Studio with devenv /force /uninstall and Installed again
  • i did also try to install w_fcompxe_novsshell_2013.4.190.exe, to see if it works, but without success. Then removed it and tried again to install 2015.
START -> Intel Parallel Studio XE 2015 -> Visual Studio integrations -> Use VS2012 opens the startup get_started.html but Fortran Components are not available and integrated.
My colleagues have the same VS 2012 SP 3 and on their PC the integration works.
Kind regards,
STU
Curious. Ok, try this.  Uninstall Fortran. Delete the "Intel Fortran" folder under Microsoft Visual Studio 11.0". Reinstall Fortran.
Smiljan_T_
I did uninstall Fortran, deleted the "Intel Fortran" folder under "Microsoft Visual Studio 11.0" and reinstalled Fortran. I get the same as before.
When you followed the repair commands, did you use "Start as Administrator" as indicated? I don't understand why the registrations succeeded but the integration doesn't show at all.
Smiljan_T_
Hi Steve,
Yes I started it as "Start as Administrator", but without success. I also was curious and installed VS 2013 Ultimate (trial version), to check if it will work. With VS 2013 the Integration works, there is only a problem with VS 2012.
Kind regards,
STU
I'm sorry, I have no idea why this would happen. I am curious why you did devenv /force /uninstall, though, rather than removing VS2012 through Control Panel. Would you please uninstall Fortran and uninstall VS2012 through Control Panel > Programs and Features? Delete the Visual Studio 11.0 folder and reboot. Then reinstall VS2012 and Fortran.
Smiljan_T_
Hi Steve,
I tried it also via Control Panel before /uninstall /force, but that did not work. Maybe it is a VS Bug or something is corrupt in Windows OS. I found a workaround and will use VS2013 instead.
Thank you very much for your efforts.
P.S. I wrote devenv /uninstall /force, but what I did mean was vs_professional /uninstall /force (http://blogs.msmvps.com/vstsblog/2013/10/15/how-to-do-a-clean-uninstall-of-visual-studio-2012/)
​Kind regards,
S
TU
