29389 Discussions
Intel compiler giving error due to whitespace in assumed rank dummy argument declaration
Shrublet
(Please See https://stackoverflow.com/questions/79834684/intel-compiler-giving-error-due-to-whitespace-in-assumed-rank-dummy-argument-dec for the original)
Consider the following code:
Module assumed_rank_module
  Implicit None
Contains
  Pure Function assumed_rank( a ) Result( s )
    Integer :: s
    Real, Dimension( .. ), Intent( In ) :: a
    s = Size( a )
  End Function assumed_rank
End Module assumed_rank_module
Gfortran is happy with this:
ijb87_local@SCLT517LINUX:~/play/stack$ gfortran --version
GNU Fortran (GCC) 15.2.0
Copyright © 2025 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
ijb87_local@SCLT517LINUX:~/play/stack$ gfortran -c -Wall -Wextra -pedantic -fcheck=all -std=f2018 -Og -g ass_rank.f90
Amdflang is happy with this:
ijb87_local@SCLT517LINUX:~/play/stack$ amdflang --version
AMD AFAR drop #6.0 03/23/25 flang version 21.0.0git (ssh://github-emu/AMD-Lightning-Internal/llvm-project  25126 b659d5b9bd0f2e3a0111a02e93ec1b3fa38a39a7)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /home/ijb87_local/tools/amd/rocm-afar-7450-drop-6.0.0/lib/llvm/bin
Build config: +assertions
Configuration file: /home/ijb87_local/tools/amd/rocm-afar-7450-drop-6.0.0/lib/llvm/bin/flang.cfg
ijb87_local@SCLT517LINUX:~/play/stack$ amdflang -c -O ass_rank.f90
Even the nvidia compiler is happy with this (after I had taken out ( Type, External ) on Implicit None ...):
ijb87_local@SCLT517LINUX:~/play/stack$ /opt/nvidia/hpc_sdk/Linux_x86_64/25.9/compilers/bin/nvfortran --version
nvfortran 25.9-0 64-bit target on x86-64 Linux -tp alderlake
NVIDIA Compilers and Tools
Copyright (c) 2025, NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
ijb87_local@SCLT517LINUX:~/play/stack$ /opt/nvidia/hpc_sdk/Linux_x86_64/25.9/compilers/bin/nvfortran -c ass_rank.f90
However ifx complains about, of all things, the space after the .. :
ijb87_local@SCLT517LINUX:~/play/stack$ ifx --version
ifx (IFX) 2025.2.0 20250605
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
ijb87_local@SCLT517LINUX:~/play/stack$ ifx -c ass_rank.f90
ass_rank.f90(11): error #5145: Invalid blank/tab
compilation aborted for ass_rank.f90 (code 1)
If I remove that space ifx is happy:
ijb87_local@SCLT517LINUX:~/play/stack$ cat ass_rank.f90
  Implicit None
Contains
    Integer :: s
    Real, Dimension( ..), Intent( In ) :: a
    s = Size( a )
This looks like a (somewhat peculiar) bug in the Intel compiler, a view that is supported on Stack Overflow. As I'm new here is this the right place to report it?
Mark_Lewy
Valued Contributor I
Still fails to compile in IFX 2025.3.1 Linux and Windows without removing the trailing space.
The Fortran standard is ambiguous on whether this is a bug or not (looking at J3/SD-007):
R814 says that array-spec can be an assumed-rank-spec (among others) (8.5.8.1 DIMENSION attribute/General)
R827 assumed-rank-spec is .. (8.5.8.7)
There is no mention of trailing or leading white-space.
Modern Fortran Explained (Fortran 2018 edition) has "... assumed rank with the syntax (..)." in 23.16.1 Assumed-rank objects, so perhaps the IFX implementation took that as inspiration?
Shrublet
It seems a bit strange that the compiler allows a space before the .. , but complains about one directly afterwards
Mark_Lewy
Yes, it does appear strange.  Also, the compiler is perfectly happy with whitespace around an assumed shape argument, for example:
Real, Dimension( : ), Intent( In ) :: a
Hopefully, someone from Intel will read this and investigate further.
andrew_4619
      Integer :: s
      s = Size( a )
But it is ok in IFX in fixed form (.for file rather the .f90 file). Spaces do matter in freeform but do ".." and ")" count as lexical tokens.....?
JFH
Both ".." and ")" are lexical tokens by F2023 3.95 6.2.6.
andrew_4619
In free source form blank characters shall not appear within lexical tokens other than in a character context or in
a format specification. Blanks may be inserted freely between tokens to improve readability; for example, blanks
may occur between the tokens that form a complex literal constant. A sequence of blank characters outside of a
character context is equivalent to a single blank character.
Standard quote. It says bug.
Igor_V_Intel
I have escalated it to Intel support, so,  Intel development team should take a look and hopefully fix it in the upcoming compiler versions.
