29285 Discussions
Intel equivelent of CVF EOF function
tim_coletta
I'm trying to convert to Intel 7.0 from CVF and noticed that Intel doesn't seem to have a function similar to CVF's EOF function. The code is looping through a number of files and checks for empty files using the following lines:
REWIND (UNIT = UNITNO (INDEX))
ENDFIL = EOF (UNITNO (INDEX))
Does Intel 7.0 have a similar function that I just haven't found, or am I going to have to try and read from each file to determine if it is empty?
Tim Coletta
Steven_L_Intel1
Intel Fortran doesn't have EOF yet. You'll have to do the test READ yourself. (This would also be more portable.)
Steve
Xj_Kong
So try to spot all EOF() clauses in the CVF environments and convert to test iostat.
Arjen_Markus
An alternative might be to emulate this function using something like:
logical function eof(unit)
    integer :: unit
    character(len=1) :: onechar
    integer :: ierr
    read( lun, iostat = ierr, '(a)' ) onechar
    eof = ierr /= 0
end function
If there are unformatted files, you will need to extend this. And you may want to distinguish between an error and a "true" end-of-file.
mecej4
Change Line-8 of the code in #4 to eof = ierr /= -1 to exclude EOR and other conditions, and note that the specific value dedicated to signify EOF is compiler-dependent, but you can USE ISO_FORTRAN_ENV and use the named constant IOSTAT_END instead.
