I'm trying to convert to Intel 7.0 from CVF and noticed that Intel doesn't seem to have a function similar to CVF's EOF function. The code is looping through a number of files and checks for empty files using the following lines:
REWIND (UNIT = UNITNO (INDEX))
ENDFIL = EOF (UNITNO (INDEX))
Does Intel 7.0 have a similar function that I just haven't found, or am I going to have to try and read from each file to determine if it is empty?
Tim Coletta
Tim Coletta
Intel Fortran doesn't have EOF yet. You'll have to do the test READ yourself. (This would also be more portable.)
Steve
Steve
So try to spot all EOF() clauses in the CVF environments and convert to test iostat.
An alternative might be to emulate this function using something like:
logical function eof(unit)
integer :: unit
character(len=1) :: onechar
integer :: ierr
read( lun, iostat = ierr, '(a)' ) onechar
eof = ierr /= 0
end function
If there are unformatted files, you will need to extend this. And you may want to distinguish between an error and a "true" end-of-file.
Change Line-8 of the code in #4 to eof = ierr /= -1 to exclude EOR and other conditions, and note that the specific value dedicated to signify EOF is compiler-dependent, but you can USE ISO_FORTRAN_ENV and use the named constant IOSTAT_END instead.
