29386 Discussions
Intel fortran 15 traceback information
Hossein_T_
I have a simple code like this below and I compile it with  " ifort  -O0 -debug -g -traceback   -check all  -ftrapuv   tracback.f90  ". Apparently there is a runtime error with a(1000)=2. IFORT catches the error however it does not print the traceback information as it used to do. What am I missing?
I use: Ubuntu x64 14.04 with GCC4.8.2 , Intel Fortran Version 15.0.0.090 Build 20140723
program helow
   integer, allocatable :: a(:)
   allocate(a(10))
   a=1; a(1)=2
   a(1000)=2
   print *,a
end program
Thank you.
Alexis_R_
Check whether your environment has the variable FOR_DISABLE_STACK_TRACE set. This disables stack trace printing.
Kevin_D_Intel
I am unable to reproduce this on our side. The traceback is provided under our Ubuntu14.04 LTS system (see details below). I’m not sure what might be hampering it on yours.
Do you have other ifort versions installed that you can try?
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 14.04 LTS
Release:        14.04
Codename:       trusty
$ uname -a
Linux xxxxxxxxx 3.13.0-24-generic #46-Ubuntu SMP Thu Apr 10 19:11:08 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
$ gcc --version
gcc (Ubuntu 4.8.2-19ubuntu1) 4.8.2
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.090 Build 20140723
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
$ ifort -O0 -debug -g -traceback -check all -ftrapuv traceback.f90
$ ldd a.out
        linux-vdso.so.1 =>  (0x00007fff5ebfe000)
        libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f426eb00000)
        libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f426e8e1000)
        libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f426e6dd000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f426e317000)
        libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f426e0ff000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f426ee1d000)
$ ./a.out
forrtl: severe (408): fort: (2): Subscript #1 of the array A has value 1000 which is greater than the upper bound of 10
Image              PC                Routine            Line        Source
a.out              00000000004045D0  Unknown               Unknown  Unknown
a.out              0000000000402A7B  MAIN__                      9  traceback.f90
a.out              000000000040247E  Unknown               Unknown  Unknown
libc.so.6          00007FF8A1F1AEC5  Unknown               Unknown  Unknown
a.out              0000000000402389  Unknown               Unknown  Unknown
Hossein_T_
Thanks David. I also have intel 14.0.3.174 and same behaviour. I tested with both and everything looks like your except the outcome. Something looks terribly wrong in my OS then.
Alexis_R_
Hossein_T_
That was it :-). Thank you. There is also a discussion here: http://dev-archive.ambermd.org/200702/0000.html
