29386 Discussions
Intel fortran compiler in Netbeans 6.7
acortesp_1142
I want to run the Intel Fortran Compiler 11.061 in Netbeans 6.7 to run in Windows Vista but I don't how to produce a makefile. I would appreciate some help on it. Thanks.
ArturGuzik
Valued Contributor I
Take a look at the Section "Building App from the command line" and "Using Makefiles to Compile Your Application", especially, in the Help. If you have MKL you can find examples also there.
Netbeans uses probably standard makefile, so you can also check Gnu make as well as CMake.
A.
