Hello:
I'm trying to help a coworker who is getting a linker error that says that msobj80.dll is a "bad DLL or entry point". He has IVF 11.0.038 and is using the Visual Studio 2008 Shell (with SP1).
From various searches, it looked like adding msobj80.dll into his C:\\Program Files\\Microsoft Visual Studio 9.0\\Common7\\IDE directory may help - but it didn't.
Any other solutions out there?
Michael
Sorry - I meant that he's using 11.1.038. But yes, I double checked, and he's running theVS2008 shell. Is it possible that the wrong linker is being used? How can I check which linker is being called? The BuildLog doesn't give an indication.
Michael
Under Linker > General, set Suppress Startup Banner to No and rebuild.
The version number it gave for the linker was 9.00.21022.08.
Michael
The one we had copied there for him was from his C:\Program Files\Microsoft Visual Studio 9.0\VC\Bin\amd64 directory. That also has a version number of 9.0.21022.8 (but I guess it was a bad idea to use that one because it's for 64-bit machines?).
We have now copied over the "correct" version - the one I have on my machine in the ......\Common7\IDE directory, and things are finally working.
Thanks for your help!
Michael
