Passing values from C to Fortran
Roop
Hello again Fortran users,
I've been working with mixed language programming for a short while now, and am using Visual Studio 2005 with the Intel Fortran compiler. My goal is to assign values to variables in C++, pass those values to a fortran subroutine, execute some equations, and pass the new variable values back to C. I've started with a simple program, just to test if I am passing values correctly. My c++ program is calling to a fortran static library.
In CPROG.cpp:
[cpp]#include "stdafx.h"
#include "CPROG.h"
#include
#include
using namespace std;
extern "C"
		void __cdecl FORTRANSUBR();
int main()
	VCOM.XX.VMA = 0;
	cout << "VMA = ";
	cin >> VCOM.XX.VMA;	// I want this value passed into Fortran
	cout << "\n" << VCOM.XX.VMA << " is the value for VMA in (C).\n";
	FORTRANSUBR();
	return 0;
}[/cpp]
In CPROG.h:
[cpp]extern "C"
	extern struct vcomblock_type
		struct
			float   VMA;		// Edited down for simplicity; this is the 481 location in Fortran
		} XX;
	} VCOM;
}[/cpp]
In FORTRANPROG.F90:
[fxfortran]	Subroutine FORTRANSUBR
	Include 'FORTRANINC.inc'
    	print *, VMA, " is the value for VMA in (Fort)."
	RETURN
	END[/fxfortran]
In FORTRANINC.inc:
[fxfortran]!.............local...............
	Common /VCOM/ xx
	EQUIVALENCE (XX( 481),VMA  ) 	! This being the 481 location in this fortran file; Edited down for simplicity.[/fxfortran]
My output looks like the following:
VMA = 2
2 is the value for VMA in (C).
0.0000000E+00 is the value for VMA in (Fort).
I have the Linker > Additional Library Directories/Dependencies set correctly to the fortran .lib file. Is there a reason why my value isn't passing correctly? Thanks in advance for your thoughts.
Roop
I've resolved this problem;
Earlier in my program, I declared a dependency to VMA as a 'double' instead of 'float'. Fortran would not read the value as it was expecting a REAL (4).
