29277 Discussions
Intel graphic library routines should be updated for x64.
coolman
For example, function
LINETOAREX
result = LINETOAREX (loc(fx), loc(fy), loc(tx) loc(ty), loc(C), loc(S), cnt)
fx
(Input) INTEGER(2). From x viewport coordinate array.
fy
(Input) INTEGER(2). From y viewport coordinate array.
tx
(Input) INTEGER(2). To x viewport coordinate array.
ty
(Input) INTEGER(2). To y viewport coordinate array.
C
(Input) INTEGER(4). Color array.
S
(Input) INTEGER(4). Style array.
cnt
(Input) INTEGER(4). Length of each coordinate array; also the length of the color array and style array. All of the arrays should be the same size.
in file ifqwin.f90,
INTERFACE
INTEGER(2) FUNCTION LINETOAREX(PFX,PFY, PTX, PTY, PC, PS, COUNT)
!DEC$ ATTRIBUTES DEFAULT :: LINETOAREX
INTEGER(4) PFX,PFY, PTX, PTY, PC, PS, COUNT
!DEC$ ATTRIBUTES DECORATE, C, ALIAS:"_linetoarrayex" :: LINETOAREX
END FUNCTION
END INTERFACE
for x64, the red part is incorrect
andrew_4619
OK  LINETOAREX is an Intel creation it is not a thin wrapper to sdk graphic functions but one woudl assume under the lid it makes a series of sdk calls for some other C library.
There is a bug as the OP describes. The intel help show it passed with loc(var), the Intel interface does not reflect that. One can seen why despite being wrong it will still work. In X64 it will not down to the different address sizes. A throwback. Passing without loc will give an error as you will be passing arrays to a scaler so the compile will show and error (which you can set an option for  it to ignore).
Andrew_Smith
Valued Contributor I
Those arguments are not memory addresses. So why would they need different size integers for 64 bit?
garraleta_fortran
How well MOVETO and LINETO work together
coolman
when PARALLEL implement, moveto and lineto together have to run asynchronously
coolman
see the call
Andrew_Smith
Your call is compatible with the interface declaration. The arguments are declared with the Fortran default of pass by reference
Andrew_Smith
You don't need to add loc(...) to your arguments since the address will be passed anyway in Fortran. Unless the interface specifies to pass by value
coolman
the call usage is from the help document. when compilered , warning #6075: The data type of the actual argument does not match the definition. [LOC]
garraleta_fortran
In Intel Visual Fortran Composer XE 2013 with Visual Studio 2008, it works fine in 32-bit and fails in 64-bit
coolman
It is very strange that the pragram can run successfully when compilered with optimization options on.
andrew_4619
