Intel oneAPI bug with submodules
Juergen_R_R
Valued Contributor II
As I don't have priority support for oneAPI (only for the 'traditional' compiler series), I post this here, in hope that someone from the Intel team picks it up. Apparently, Intel oneAPI throws an error on standard-conformant code, namely when defining a UDT with private components in a module, and then using its structure constructor in a submodule of that module, Intel oneAPI (both 21 and 22) complain:
bla.f90(30): error #6053: Structure constructor may not have components with the PRIVATE attribute [42]
t = t1(42)
However, the submodule should have the same scoping unit as its (parent) module, so the structure constructor should be usable in the submodule. Here is the reproducer:
module foo
  implicit none
  private
  type t1
     private
     integer :: i
  end type t1
  interface
     module function xxx ()
       integer :: xxx
     end function
  end interface
end module foo
submodule (foo) foo_s
  implicit none
contains
    integer :: xxx
    xxx = 17
  end function
  pure function func () result (t)
    type(t1) :: t
    t = t1(42)
  end function func
end submodule foo_s
Steve_Lionel
You need to specify which compiler version you are using. "oneAPI" is not sufficiently descriptive. Note that if you have active support for Parallel Studio XE, you also have support for the oneAPI compilers.
I can reproduce this error with ifort (Classic) 2021.5.0, and agree that it is a bug.
Steve_Lionel
Juergen_R_R
Indeed, sorry for not having specified the detailed version, it was Intel(R) 64, Version 2021.4.0 Build 20210910_000000.
Regarding the support, I have to check with our IT department, whether they still have their license for Parallel Studio XE.
Barbara_P_Intel
I filed a bug report on your behalf, CMPLRIL0-34524. I'll let you know when a fix is available.
Happy New Year!
Barbara_P_Intel
This erroneous error message is gone with ifort 2021.6.0 which is part of oneAPI HPC Toolkit 2022.2 that was recently released.
Please check it out!
