29389 ディスカッション
Interaction Between Intel Fortran DLL and VB 6.0
Mark_Gracey
ビギナー
527件の閲覧回数
I started a thread called "Intel Fortran DLL for use with VB 6.0" on 29th March, and was provided with a solution.
That was a test case.
I have now tried to apply the solution to a more realistic case, and get a completely different problem, which occurs earlier in the process trhan the previous problem.
In this case I get the error:
Compile error:
Member already exists in object module from which this object module derives
I have attached the DLL and the calling program.
Can anyone see the problem?
Mark.
0 件の賞賛
0 返答(返信)
返信
