29281 Discussions
Interesting Observation with Intel Fortran and VS 2019
JohnNichols
Valued Contributor III
The automatic formatting in VS has a problem if there is a do statement in an if block.  The following statements give an example:
if(RCA(M, Zi) .eq. 0) then
    else
        allocate (YPLOTA(P,RCA(M, Zi)), STAT = astat)
        if(astat == 0) then
            write(*,*)"Allocated matrix RCA(K,K)"
        else
            stop "Failed to allocate matrix RCA(K,K)"
        end if
        do 400 i = 1,51
            if(zi .eq. Z(i)) then
                YPLOTA(:,count) = X(:,i)
                count = count + 1
            endif
400 end do
    YMAX = maxval(YPLOTA)
Line 17 and line 20 are incorrectly placed if you are following the intent of the algorithm for setting out the code.  This is pulled from a few hundred lines, all the lines after 20 are incorrectly placed.
I do not know if there is a fix?
andrew_4619
The numbers mess thing up, why have those at all?
DavidWhite
I think that using the do numbering confuses the formatting between free format and fixed formatting.
When DO / END DO is used without numbers, the indentation normally works for me.
