29560 Discussions
Internal Compiler Error with use of a parameterized derived type with type-bound procedures
FortranFan
This builds further on the code shown in the topic  https://software.intel.com/en-us/forums/topic/536578.  The use of the derived type in a program results in an internal compiler error:
MODULE m
   USE, INTRINSIC :: ISO_FORTRAN_ENV, ONLY : I4 => INT32, SP => REAL32, DP => REAL64
   IMPLICIT NONE
   PRIVATE
   PUBLIC :: I4, SP, DP
   TYPE, PUBLIC :: t(k,n)
      PRIVATE
      INTEGER(I4), KIND :: k = SP
      INTEGER(I4), LEN  :: n = 1
      REAL(k) :: m_X(n)
   CONTAINS
      PRIVATE
      PROCEDURE, PASS(This) :: GetX_SP
      PROCEDURE, PASS(This) :: GetX_DP
      PROCEDURE, PASS(This) :: SetX_SP
      PROCEDURE, PASS(This) :: SetX_DP
      GENERIC, PUBLIC :: X => GetX_SP, GetX_DP
      GENERIC, PUBLIC :: SetX => SetX_SP, SetX_DP
   END TYPE t
CONTAINS
   PURE FUNCTION GetX_SP(This) RESULT(RetVal)
      CLASS(t(SP,*)), INTENT(IN) :: This
      !.. Function result
      REAL(SP), ALLOCATABLE :: RetVal(:)
      RetVal = This%m_X
      RETURN
   END FUNCTION GetX_SP
   PURE FUNCTION GetX_DP(This) RESULT(RetVal)
      CLASS(t(DP,*)), INTENT(IN) :: This
      !.. Function result
      REAL(DP), ALLOCATABLE :: RetVal(:)
      RetVal = This%m_X
      RETURN
   END FUNCTION GetX_DP
   PURE SUBROUTINE SetX_SP(This, Arr)
      CLASS(t(SP,*)), INTENT(INOUT) :: This
      REAL(SP), INTENT(IN)          :: Arr(:)
      IF (SIZE(Arr) == This%n) THEN
         This%m_X = Arr
      END IF
      RETURN
   END SUBROUTINE SetX_SP
   PURE SUBROUTINE SetX_DP(This, Arr)
      CLASS(t(DP,*)), INTENT(INOUT) :: This
      REAL(DP), INTENT(IN)          :: Arr(:)
         This%m_X = Arr
      END IF
      RETURN
   END SUBROUTINE SetX_DP
END MODULE m
PROGRAM p
   USE m, ONLY : I4, DP, t
   IMPLICIT NONE
   !.. Local variables
   TYPE(t(DP,5)) :: foo
   REAL(DP) :: x(5)
   PRINT *, " Test #74: PDT"
   PRINT *, " foo%k = ", foo%k
   PRINT *, " foo%n = ", foo%n
   x = -1.0_dp
   CALL foo%SetX(x)
   PRINT *, " foo%x = ", foo%X()
   STOP
END PROGRAM p
1>------ Build started: Project: TestFor, Configuration: Debug Win32 ------
1>Unlock PDB file
1>Compiling resources...
1>TestFor.rc
1>Microsoft (R) Windows (R) Resource Compiler Version 6.3.9600.17298
1>Copyright (C) Microsoft Corporation.  All rights reserved.
1>Compiling with Intel(R) Visual Fortran Compiler XE 15.0.1.148 [IA-32]...
1>TestMod.f90
1>C:\..\TestMod.f90(56): warning #7026: Non-standard extension.   [T#4&*]
1>C:\..\TestMod.f90(69): warning #7026: Non-standard extension.   [T#8&*]
1>TestFor.f90
1>fortcom: Fatal: There has been an internal compiler error (C0000005).
1>compilation aborted for C:\..\TestFor.f90 (code 1)
1>
1>Build log written to  "file://C:\..\Debug\Win32\TestForBuildLog.htm"
1>TestFor - 1 error(s), 2 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Thanks - we'll check it out.
This looks to be the same as https://software.intel.com/en-us/forums/topic/535467 . Escalated as issue DPD200363307.
This has been fixed in our sources. I expect the fix to appear in Update 2, planned for February.
FortranFan
Steve,
The code in the original post compiles fine now, but it generates run-time exception (as shown below) if /check:bounds compiler option is specified.  Any idea why?
  Test #74: PDT
  foo%k =  8
  foo%n =  5
forrtl: severe (408): fort: (2): Subscript #1 of the array M_X has value 1 which
 is greater than the upper bound of 0
Image              PC        Routine            Line        Source
TestFor32.exe      01284C54  Unknown               Unknown  Unknown
TestFor32.exe      012819F4  _M_mp_SETX_DP              73  TestMod.f90
TestFor32.exe      01281DA9  _MAIN__                    17  TestFor.f90
TestFor32.exe      012EEA62  Unknown               Unknown  Unknown
TestFor32.exe      012EF27A  Unknown               Unknown  Unknown
TestFor32.exe      012EF3CD  Unknown               Unknown  Unknown
kernel32.dll       76D9338A  Unknown               Unknown  Unknown
ntdll.dll          7795BF32  Unknown               Unknown  Unknown
ntdll.dll          7795BF05  Unknown               Unknown  Unknown
Press any key to continue . . .
FortranFan
Possibly connected with https://software.intel.com/en-us/forums/topic/536334 and https://software.intel.com/en-us/forums/topic/536564?
Very likely. I added your case to the report of that problem and asked the developers for an update.
