Internal Compiler Error
Ben3
I get this error while trying to compile using the latest version of ifort on 64-bit Linux:
ifort -O0 -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o jacksort.o -c jacksort.f90
0_12307
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
It occurs no matter what optimisation level I select.
I've attached the offending .f90 file, it looks perfectly fine to me.
Any suggestions?
Cheers,
Ben
EDIT:
Attached tar.gz file containing all source files and a makefile. Compile with "make cmanalysis". This is the output I get:
[bash]ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o kinds.o -c kinds.f90
ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o constants.o -c constants.f90
ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o types.o -c types.f90
ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o parameters.o -c parameters.f90
ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o errors.o -c errors.f90
ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o stringfunctions.o -c stringfunctions.f90
ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o matrixfunctions.o -c matrixfunctions.f90
ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o sorting.o -c sorting.f90
ifort -O2 -xHost -ipo -ip -cpp -D_WP_=dp -convert big_endian -assume byterecl -vec-report -par-report -heap-arrays 8192 -I/home/weyl/ben/programs/intel/mkl/include/intel64/lp64 -o jacksort.o -c jacksort.f90
0_12307
compilation aborted for jacksort.f90 (code 1)
make: *** [jacksort.o] Error 1
[/bash] My version of ifort:
[bash]bmenadue@weyl ~>ifort --version
ifort (IFORT) 12.0.2 20110112
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.[/bash]
mecej4
Not much can be said about the file that you posted because the source code for the modules, which you did not provide, is also needed.
Ben3
Sorry, I forgot about the modules. I'm attaching them to the original post.
mecej4
Thanks. I felt that the code was too large to serve as a "reproducer" and created a much truncated version, which I posted separately here.
Escalated as issue DPD200167044.
Ben3
Thanks, mecej4.
This got fixed in the 13.0 compiler - sorry for not updating the thread.
