29648 Discussions
Problem using nested type-bound procedures and coarrays
FlyingHermes
I'm having some problems with a deried-type coarray and type-bound procedure.
What I'm basically trying to do
I've defined a derived-type coarray which has 2 type-bound procedures (Sub1 and Sub2), one (Sub2) calling the other (Sub1).
When I'm calling the Sub2, a segmentation fault error.
The code is given below, and it is also attached
[fortran]
Program Main
  use MyType_Module              ,only:  MyType
  implicit none
  type(MyType)  ,codimension
  • ::      CoVar
      write(*,"(2x,'[Main]:',i0,'/',i0,': Starting')") This_Image(),Num_Images()
      write(*,"(2x,'[Main]:',i0,'/',i0,': Calling CoVar%Sub1')") This_Image(),Num_Images()
      call CoVar%Sub1()
      write(*,"(2x,'[Main]:',i0,'/',i0,': Calling CoVar%Sub2')") This_Image(),Num_Images()
      call CoVar%Sub2()
    End Program
  • [/fortran]
    [fortran]
    Module MyType_Module
      implicit none
      private
      public        ::      MyType
      Type          ::      MyType
      contains
        procedure   ::      Sub1
        procedure   ::      Sub2
      End Type
      contains
    Subroutine Sub1( This )
      implicit none
      class(MyType)  ,codimension
  •   ,intent(in)  :: This
      write(*,"(6x,'[Sub1]:',i0,'/',i0,': Do nothing')") This_Image(),Num_Images()
    End Subroutine
  • Subroutine Sub2( This )
      implicit none
      write(*,"(4x,'[Sub2]:',i0,'/',i0,': Calling This%Sub1')") This_Image(),Num_Images()
      call This%Sub1()
      write(*,"(4x,'[Sub2]:',i0,'/',i0,': Exiting')")
    End Subroutine
  • End Module
    [/fortran]
    The above code can be compiled with the following commands:
    [bash]ifort -coarray -coarray-num-images=2 -c mytype_module.f90 -o mytype_module.o
    ifort -coarray -coarray-num-images=2 -c main.f90 -o main.o
    ifort -coarray -coarray-num-images=2 main.o mytype_module.o -o a.out[/bash]
    Anonymous66
    Valued Contributor I
    I have escalated this to the developers. The issue number is DPD200243988. I will keep you informed of any updates I receive.
    Annalee
    Anonymous66
    A fix has been found for this issue. We are currently planning to include it in the next major release which is currently scheduled for later this year.
    Annalee
    FlyingHermes
    This error is still present in ifort version 13.1.3.
    Any idea when the next major release you are mentioning will be available  ?
    September.
