29322 Discussions
Internal Procedures as actual arguements
adrianholt
The FORTRAN standard will not allow internal procedures to be actual arguements to another procedure. COMPAQ FORTRAN seems to allow this, which is a very nice feature. However the contained internal procedure I am using is an ARRAY FUNCTION which causes a compile error in COMPAQ. Is there any way around this so I can still use a CONTAINED ARRAY FUNCTION?
Example Below::
module obsvTest3
implicit none
private
integer, parameter :: iDim = 2
contains
subroutine test1 ()
! double precision, external :: testfun
! double precision, dimension(iDim), external :: testfun
! external :: testfun
call testmethod (testfun)
contains
function testfun ()
! double precision :: testfun
double precision, dimension(iDim) :: testfun
testfun = 1d0
end function testfun
end subroutine test1
subroutine testmethod (dFun)
double precision, dimension(iDim), external :: dFun
! double precision, external :: dFun
! external :: dFun
double precision, dimension (iDim) :: dLocal
! double precision :: dLocal
dLocal = dFun()
end subroutine testmethod
end module obsvTest3
james1
First, you want to pass a pointer to the routine as in CALL TESTMETHOD(LOC(TESTFUN)). Then in TESTFUN define an interface for the function it is to call, and assign the function pointer as in:
subroutine testmethod (lpFun)
interface
function testfun ()
  end function
end interface
integer (int_ptr_kind()) lpFun
pointer (dFunPtr, testfun)
dFunPtr = lpFun
dLocal = testfun()
James
Steven_L_Intel1
Your main problem is that you cannot declare an array-returning function using EXTERNAL. You must use an INTERFACE for this. If you do that, you run into an annoying aspect of the language which makes host-associated definitions invisible inside INTERFACE blocks. So you have to do it this way instead:
module mydefs
end module mydefs
module obsvTest3
use mydefs
implicit none
private
contains
subroutine test1 ()
contains
function testfun ()
testfun = 1d0
interface
  function dFun
  use mydefs
  double precision, dimension(iDim) :: dFun
  end function dFun
  end interface
dLocal = dFun()
Steve
