29359 Discussions
Internal compiler error (calculation of dimension)
Diehl__Martin
The attached code results in an ICE with ifort 19.1.2.254 and older versions.
Seems to be related to the complex calculation of dimensions.
Johannes_Rieke
New Contributor III
Hi Martin, I can confirm the ICE.
replacing
integer(C_SIGNED_CHAR), dimension(size(bytes_raw,kind=pLongInt)-int(headerLen,pLongInt)) :: bytes
with
integer(C_SIGNED_CHAR), allocatable :: bytes(:)
  allocate(bytes(size(bytes_raw,dim=1,kind=pLongInt)-int(headerLen,pLongInt)))
let the ICE disappear. I'm not sure, whether it helps you, because the context is not clear to me and you maybe know that already and wanted just to inform us.
However, an ICE should always be reported and a ticket be opened. All users will hopefully benefit from it
Diehl__Martin
thanks for the confirmation
I actually use the same work around, so the ICE does not impact me a lot. Just two more lines and some #ifdefs
FortranFan
@Diehl__Martin ,
Agree re: the ICE, it's great you're reporting it, it helps everyone.
Re: a workaround, can you consider an alternative as shown below?
integer(C_SIGNED_CHAR), dimension(chunkLen)                         :: bytes
Something to keep in mind always is what's easier for a future reader of your code (which may be you yourself in a new incarnation which is basically any moment following the time you author your first draft) is also often easier on the processor (compiler).
Diehl__Martin
@FortranFan: Thanks for the suggestion
I agree that that would be the better solution for this MWE. In the real library there are more functions and I want define always as `size(bytes) = size(bytes_raw) - headerLen`.
