Dear Intel developers,
Compilation of this subroutine optrms.F (See attachment) leads to an **Internal compiler error: segmentation violation signal raised** with -O3 options. This error disappears with -O2
The compilation instructions is /share/apps/intel/composer_xe_2013_sp1.2.144/bin/intel64/ifort -i8 -r8 -pc64 -auto -vec-report0 -warn nousage -cxxlib
fort version: Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.2.144 Build 20140120
Linux kernel: 2.6.32-279.14.1.el6.x86_64
Note that the program compiled with ifort version: Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.106 Build 20131008
Thanks a lot for your help. Valérie
Valérie,
Thank you for reporting this internal error and for the convenient reproducer. I reproduced the error and directed it to the Developers for investigation and repair (see internal tracking id below).
The error occurs within the High-Level Optimization phase enabled with -O3 so as you noted the work around at this time is to use the -O2 optimization level.
I will keep the post updated on the status of a fix as I learn it.
(Internal tracking id: DPD200254225)
Dear Kevin,
I have the same error when compiling my codes:
ifort -O3 -xHost -ipo -openmp Declaration_2014feb27C.f90 Modsgrowth_2014mar14A.f90 Growth_2014mar14A.f90
Then I got:
ipo: remark #11000: performing multi-file optimizations
ipo: remark #11006: generating object file /tmp/ipo_ifortPr3Cem.o
** segmentation violation signal raised **
Access violation or stack overflow. Please contact Support.
ifort: error #10106: Fatal error in /opt/intel/composer_xe_2013_sp1.2.144/bin/intel64/fortcom, terminated by segmentation violation
ifort: error #10014: problem during multi-file optimization compilation (code 1)
Linux kernel is 3.2.0-4-amd64
Could you please look at the attached codes?
Lam
@Valérie - The internal error you reported is fixed in the Intel® Composer XE 2013 Update 3 release (Version 14.0.3.174 Build 20140422) and the latest Intel® Parallel Studio XE 2015 release for Linux (Version 15.0.0.090 Build 20140723)
@Lam - Your issue does not share the same root cause as Valérie’s issue and is not addressed at this time. The error you experienced occurs with the Intel® Composer XE 2013 Update 2 release but later releases seemingly enter into an indefinite compilation. There is a new/separate defect report filed Development tracking your issue (see internal tracking id below). The only means of avoidance is to compile at -O2 (with -ipo). I will update this post as I learn more.
(Internal tracking id: DPD200360970)
