I have recently run into an internal compiler error with ifort 15.0, for a piece of code that works just fine with Ifort 14.0. I think this is a regression bug.
The catastrophic error shows up when I create a polymorphic pointer to an extended type with a long name, which is defined within a module that also has a long name. I see the error whenever the sum of the two names (module + type) is equal to or larger than 110 characters.
Please consider the following code:
module module________________with_a_long_name_of_55_characters
type :: type__________________with_a_long_name_of_55_characters
integer :: i
end type type__________________with_a_long_name_of_55_characters
end module module________________with_a_long_name_of_55_characters
program p
use module________________with_a_long_name_of_55_characters, only: &
implicit none
class(type__________________with_a_long_name_of_55_characters), pointer :: sim
allocate(type__________________with_a_long_name_of_55_characters::sim)
sim%i = 4
write(*,*) sim%i
end program p
Compiling with
$ ifort -stand f08 p.f90 -o -p
I see the error
101004_2054
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for p.F90 (code 1)
The same code is correctly compiled by ifort 14.0.
$ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.2.164 Build 20150121
Yaman
We've identified the underlying problem, which is in all compilers but it's very dependent on memory layout. We hope to get at least a partial fix in for XE 2015 Update 4, and a more comprehensive fix in for the 16.0 compiler.
Thanks - we'll check it out.
Escalated as issue DPD200369789. I was intrigued to note that I could not reproduce this on Windows, just Linux. 15.0.3 has the same bad behavior. Thanks for the nice example.
The error is still present on Windows when generating 32-bit objects:
S:\lang>ifort /stand:f08 longn.f90 Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 15.0.3.208 Build 20150407 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. fortcom: Fatal: There has been an internal compiler error (C0000005). compilation aborted for longn.f90 (code 1)
So it is... Thanks.
This is good news, I look forward to having ifort 15.0.4 on our cluster.
Thank you. Yaman.
Not to correct Steve, but the actual update will be XE 2015 Update 5, due out later this year.
--Lorri
It's for large values of 4....
The "more comprehensive" fix is planned for 16.0.2, scheduled for February.
