29641 Discussions
Internal compiler error with parametrized derived types
Max_N_
The following does not compile with 15.0.1:
module m_module
implicit none
type :: TypeB(int)
     integer, len :: int
     integer      :: val(int)
end type
type :: TypeA
     type(TypeB(:)), allocatable :: bar
end type
type(TypeA) :: foo
end module m_module
but returns
101004_2049
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for param_dt_bug.f90 (code 1)
Is it not standard F2003?
Cheers,
Max
Kevin_D_Intel
This is an internal compiler error and not a code issue. I reproduced the internal error with the 15.0 Update 1 and Update 2 but it appears fixed in the 15.0 Update 3 noted below so perhaps you can grab this update.
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 6 , Version 15.0.3.187 Build 20150407
