The following simple code works fine with gfortran but fails with an unexpected "has stopped working" message with Intel compiler (version 16, update 1). It feels like one of those simple code constructs that has worked umpteen times previously with Intel compiler but something has changed which causes it to fail now. But I just can't figure out the problem.
module m
use, intrinsic :: iso_c_binding, only : c_char, c_int, c_ptr, c_f_pointer
use, intrinsic :: iso_fortran_env, only : output_unit
implicit none
contains
subroutine Fsub( Str, LenStr ) bind(C, name="Fsub")
!.. Argument list
type(c_ptr), intent(in), value :: Str
integer(c_int), intent(in), value :: LenStr
blk: block
character(kind=c_char,len=LenStr), pointer :: f_str => null()
call c_f_pointer( Str, f_str )
write(output_unit,*) "In Fsub: Str is ", f_str
f_str => null()
end block blk
return
end subroutine Fsub
end module m
#include <string.h>
void Fsub(const char *, int);
int main()
const char * s = "Hello World!";
int len_s;
len_s = strlen(s);
Fsub(s, len_s);
return(0);
C:\temp>ifort /c /standard-semantics /warn:all f.f90 Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R ) 64, Version 16.0.1.146 Build 20151021 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. C:\temp>cl /c c.c Microsoft (R) C/C++ Optimizing Compiler Version 18.00.40629 for x64 Copyright (C) Microsoft Corporation. All rights reserved. c.c C:\temp>link c.obj f.obj /out:p.exe Microsoft (R) Incremental Linker Version 12.00.40629.0 Copyright (C) Microsoft Corporation. All rights reserved. C:\temp>p
It isn't the C_F_POINTER, the error is happening as soon as the BLOCK is entered. We'll take a closer look.
Escalated as issue DPD200381625.For some reason the compiler is trying to copy the string just setting up the pointer, but using a NULL address to do it.
Thanks Steve for your follow-up. Yes, BLOCK seems to be the problem - it works without it.
