Internal compiler error
Moved to separate thread
Note - first three replies are in reverse order.
Michael_Barkhudarov
That error message can have many possible, unrelated causes. It is always a compiler bug, but not always the same one! Can you attach a short (if possible) source file that gets this error, along with the command line used to do the compile?
For more information, see the Knowledge Base article Internal Compiler Error
Hi Steve,
I get this error compiling a FORTRAN subroutine with the following options:
Compiling with Intel Visual Fortran 11.1.048 [Intel 64]...
ifort /nologo /O3 /assume:buffered_io /fpp /DWIN32 /DP4 /Qopenmp /warn:none /fp:precise /module:"release/" /object:"release/" /libs:static /threads /4Yportlib /c /MD /extfor:F /Qvc8 /Qlocation,link,"C:Program Files (x86)Microsoft Visual Studio 8VCbinamd64" "D:v9mod5prehydhydr3dgdcat.F"
ifort: command line warning #10212: /fp:precise evaluates in source precision with Fortran.
fortcom: Fatal: There has been an internal compiler error (C0000005).
compilation aborted for D:v9mod5prehydhydr3dgdcat.F (code 1)
I am not sure how to send you the source file on this forum. Let me know please. The full source contains a few hundred files; only one fails like this.
Michael Barkhudarov
Michael,
This error is very generic and can have many possible causes. See the link in my signature below for how to attach a source. Please start a new topic in the forum for this.
mingkaili
I meet the same problem in ivf 11.1 for win64. When I try to complie the Siesta-3.0-b, which you can get from http://www.icmab.es/siesta/index.php, the same fatal error appears for the file born_charge.F.
I check the source and find that the reason is born_charge.F use siesta_options module. Please check the Line No. 9 in born_charge.F.
Itshould a Intel Complier bug. All programs of Siesta can be passed by gfortran and PGI compilers.
The sources you provided require many additional modules. The software is not downloadable without a license. Is there some way you can provide us a ZIP of the necessary files?
