ld: duplicate symbol _random_
Boris_B_
I just installed ifort 11.1_076 on an iMac running Snow Leopard OSX 10.6.2. Compiling the program below gives
ld: duplicate symbol _random_ in /opt/intel/Compiler/11.1/076/lib/libifcore.a(for_m_irand.o) and /var/folders/N2/N2BIztNnG886YvKgCphSSE+++TI/-Tmp-//iforthLPAt6.o
Grateful for any advice.
c performs
c matrix multiplication test
c double precision version
c
c reference: W.F. Eddy, "The DECstation 3100 - UNIX for Power Users"
c Chance, V.3,N.2 (1990), pp.42-47
c
c auxiliary routine: TIMER - returns elapsed cpu time in tics of .01 secs
C
PARAMETER (N=1024)
IMPLICIT DOUBLE PRECISION (A-H,O-Z)
REAL A(n,n), B(n,n), C(n,n)
REAL CPTIM, random
COMMON /RAND/ IX, IY, IZ
c CALL TIMER(ITICS0)
IX = 1333
IY = 1777
IZ = 3555
DO I = 1, N
DO J = 1, N
A(J,I) = DBLE(RANDOM(JUNK))
ENDDO
DO J = 1, N
B(I,J) = DBLE(RANDOM(JUNK))
ENDDO
ENDDO
DO I = 1, N
DO J = 1, N
C(I,J) = 0.0
DO K = 1, N
C(I,J) = C(I,J) + A(I,K) * B(K,J)
ENDDO
ENDDO
ENDDO
CKSUM = 0.0D0
DO I = 1, N
DO J = 1, N
CKSUM = CKSUM + C(I,J)
ENDDO
ENDDO
c CALL TIMER(ITICS1)
CPTIM = FLOAT(ITICS1-ITICS0) / 100.0
c output results to file
OPEN (UNIT=6,FILE='matmul.out')
WRITE (6,10000)
WRITE (6,10005) CKSUM
WRITE (6,10010) N
WRITE (6,10015) CPTIM
CLOSE (6)
STOP
10000 FORMAT (/' Matrix Multiplication Timing Test')
10005 FORMAT (' check sum = ',1PD20.5)
10010 FORMAT (' dimension of matrix = ',I4)
10015 FORMAT (' cpu time (sec) = ', F10.2 )
END
c version: Feb 23 1992
FUNCTION RANDOM(L)
c
c ALGORITHM AS 183 APPL. STATIST. (1982) VOL.31, NO.2
c
c RETURNS A PSEUDO-RANDOM NUMBER RECTANGULARLY DISTRIBUTED
c BETWEEN 0 AND 1
c
c IX, IY AND IZ SHOULD BE SET TO INTEGER VALUES BETWEEN
c 1 AND 30000 BEFORE FIRST ENTRY
c
c INTEGER ARITHMETIC UP TO 30323 IS REQUIRED
c
IX = 171 * MOD(IX,177) - 2 * (IX/177)
IY = 172 * MOD(IY,176) - 35 * (IY/176)
IZ = 170 * MOD(IZ,178) - 63 * (IZ/178)
c
IF (IX.LT.0) IX = IX + 30269
IF (IY.LT.0) IY = IY + 30307
IF (IZ.LT.0) IZ = IZ + 30323
c
c IF INTEGER ARITHMETIC UP TO 5212632 IS AVAILABLE,
c THE PRECEDING 6 STATEMENTS MAY BE REPLACED BY
c
c IX = MOD(171 * IX, 30269)
c IY = MOD(172 * IY, 30307)
c IZ = MOD(170 * IZ, 30323)
c
c ON SOME MACHINES, THIS MAY SLIGHTLY INCREASE
c THE SPEED. THE RESULTS WILL BE IDENTICAL.
c
RANDOM = AMOD(FLOAT(IX)/30269.0+FLOAT(IY)/30307.0+FLOAT(IZ)/
+ 30323.0,1.0)
c
IF (RANDOM.GT.0.0) RETURN
RANDOM = DMOD(DBLE(FLOAT(IX))/30269.0D0+DBLE(FLOAT(IY))/30307.0D0+
+ DBLE(FLOAT(IZ))/30323.0D0,1.0D0)
IF (RANDOM.GE.1.0) RANDOM = 0.999999
RETURN
END
TimP
Technically, ifort shouldn't have a pre-defined RANDOM() without USE IFPORT. You could work around that bug by EXTERNAL RANDOM. It's a legacy remainder from long ago, before Fortran standard supplied RANDOM_NUMBER and RANDOM_SEED.
