Internal compiler error
Sagan__David
Test program is below. Upon compiling:
erpsim1:~/dcs16/linux_lib/test> ifort test.f90
test.f90(27): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for test.f90 (code 1)
erpsim1:~/dcs16/linux_lib/test> ifort --version
ifort (IFORT) 14.0.0 20130728
erpsim1:~/dcs16/linux_lib/test> uname -a
Linux erpsim1.lns.cornell.edu 2.6.32-358.14.1.el6.x86_64 #1 SMP Tue Jul 16 14:24:33 CDT 2013 x86_64 x86_64 x86_64 GNU/Linux
Test also fails with V13.
module bmad_struct2
type target_point_struct
real :: r(3) = 0 ! (x, y, z)
end type
type photon_target_struct
logical :: enabled = .false.
type (target_point_struct) :: corner(4) = target_point_struct()
type (target_point_struct) :: center = target_point_struct()
end type
type photon_element_struct
type (photon_target_struct) :: target = photon_target_struct()
end type
end module
module bmad_cpp_test_mod
use bmad_struct2
contains
subroutine test2_f_photon_target ()
implicit none
type(photon_target_struct) :: f_photon_target
end subroutine test2_f_photon_target
end module
Kevin_D_Intel
And also still failing in our Composer XE 2013 SP1 Update 1. Thank you for the convenient reproducer. I will report this to Development and post updates regarding a fix or work around as I learn it.
(Internal tracking id: DPD200249412)
(Resolution Update on 09/16/2014): This defect is fixed in the Intel® Parallel Studio XE 2015 Initial Release (2015.0.090 - Linux)
Kevin_D_Intel
This issue has been fixed for our major release later this year. Development is investigating fixing in the current 14.0 release; however, that is probably not likely due to the complexity of the fix. The internal error occurs related to the default initialization. A work around would be to create an initialization routine to explicitly set the fields to zero rather than depend on default initialization.
Kevin_D_Intel
Just confirming again this issue is resolved in the Intel® Parallel Studio XE 2015 release for Linux (Version 15.0.0.090 Build 20140723) now available from the Intel® Registration Center.
Also, Development determined the complexity and associated risk to back port the fix into the current Intel® Composer XE 2013 SP1 (14.0 compiler) was too significant so please either upgrade to the newer release or continue using the earlier suggested work around.
