29381 Discussions
Internal error (an ICE?) with a parameterized derived type
FortranFan
module m
   implicit none
   type :: t(n,m)
      integer, len :: n
      integer, len :: m
      real :: x(n)
      real :: y((m-1)*n)     !.. real :: y(m*n - n) compiles ok
   end type
contains
   subroutine set(this)
      !.. Argument list
      type(t(*,*)), intent(inout) :: this
      this%x = 0.0
      this%y = 0.0
      return
   end subroutine set
end module m
------ Build started: Project: p, Configuration: Debug|Win32 ------
Compiling with Intel(R) Visual Fortran Compiler XE 15.0.2.179 [IA-32]...
m.f90
C:\..\m.f90(19): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
[ Aborting due to internal error. ]
compilation aborted for C:\..\m.f90 (code 1)
FortranFan
  • Please note the comment on line 10.
  • Is "internal errror" the same as "internal compiler error"?  The output text with the error appears different; a change with the recent update, Compiler 2015 Update 2?
FortranFan
I thought the error may have something to do with a name conflict with m; module name versus the second type parameter (even thought that won't explain the cases where the code compiles ok).  But changing one of the names, say the type parameter to p, makes no difference; the error persists.
pbkenned1
Thanks for reporting this; I can reproduce [ Aborting due to internal error. ] and I'll report this to the developers.  I assume the error is the same as 'internal compiler error', but I'll confirm that as well.
Patrick
pbkenned1
The 'Aborting due to internal error' has been reported to the developers.  I've noted in the report:
1) Changing  'real :: y((m-1)*n)' to 'real :: y(m*n - n)' will result in a clean compile
2) Asked if 'Aborting due to internal error' is the same as 'internal compiler error'
I'll pass along updates received from the developers.
Internal tracking ID:  DPD200366574
Patrick
For question 2, yes, that's another form of internal compiler error. Which message you see depends on which part of the compiler is executing and whether the error is an inconsistency detected by the compiler or an exception such as access violation.
