29653 Discussions
Internal error in declaring parametric object
Trent_Hawkins
Parallel Studio XE 2017 update 1
When compiling:
#     ifndef matrix_algebra_F90
#     define matrix_algebra_F90
      module matrix_algebra
            implicit none
            integer,parameter::x_=8
            type::matrix(size)
               integer,len::size
               complex(kind=x_)::component(0:size,0:size)
            contains
               procedure,private::initialize_matrix
        end type  matrix
            interface matrix
               module procedure matrix_source_constructor
        end interface matrix
      contains
            subroutine initialize_matrix(this,source)
                  implicit none
                  class(matrix(*))::this
                  complex(kind=x_),intent(in),optional::source(0:this%size,0:this%size)
                  if(present(source)) then
                     this%component=source
                  else
                     this%component=(0.0_x_,0.0_x_)
              end if!present(source)
        end subroutine initialize_matrix!this,source
            function matrix_source_constructor(source) result(that)
                  implicit none
                  complex(kind=x_),intent(in),optional::source(0:,0:) ! Internal error if deferred size
                  type(matrix(size(source)-1))::that
                  call that%initialize_matrix(source)
        end function matrix_source_constructor!source
  end module matrix_algebra
#     endif
I get:
internal_errors.F90(42): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
[ Aborting due to internal error. ]
compilation aborted for internal_errors.F90 (code 1)
The error disappears if I declare the dummy variable source with fixed size instead of deferred like above.
Xiaoping_D_Intel
Thanks for reporting the issue. I have reproduced the error and escalated it to developers for fixing. The bug ID is DPD200416910.
Xiaoping Duan
Intel Customer Support
