29652 Discussions
Internal error while compiling source code on Linux for 64 bits
Arjen_Markus
we are trying to build our programs for 64 bits Linux, but are stumbling on an ICE. The code compiles
fine for 32-bits, but causes the following message with 64 bits (ia64):
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
It is not clear where in the source file this is coming from. I did find out that the -g is causing the problem.
Without it, the compilation succeeds.
The platform: Linux, 64 bits, Intel Fortran 11.0
The (reduced) code that gives this problem is included below.
Arjen
module MHCallBack
abstract interface
subroutine mh_callbackiface(level)
integer, intent(in) :: level !< The severity level
end subroutine mh_callbackiface
end interface
end module MHCallBack
module MessageHandling
use MHCallBack
implicit none
public SetMessage
public GetMessageCount
public SetMessageHandling
public mess
public err
public GetMessage_MH
public resetMessageCount_MH
public getMaxErrorLevel
public resetMaxerrorLevel
integer,parameter, public :: LEVEL_DEBUG = 1
integer,parameter, public :: LEVEL_INFO = 2
integer,parameter, public :: LEVEL_WARN = 3
integer,parameter, public :: LEVEL_ERROR = 4
integer,parameter, public :: LEVEL_FATAL = 5
integer,parameter, public :: Charln = 40
integer,parameter, public :: max_level = 5
character(len=12), dimension(max_level), &
private :: level_prefix = &
(/' ', ' ', '** WARNING:', '** ERROR:', '** FATAL:'/)
interface mess
module procedure message1string
end interface
interface err
module procedure error1char
end interface
private
integer, parameter, private :: maxMessages = 3000
character(len=256), dimension(maxMessages), private :: Messages
integer , dimension(maxMessages), private :: Levels
integer , private :: messagecount
integer , private :: maxErrorLevel = 0
integer , private :: thresholdLvl = 0
integer, save :: lunMess = 0
logical, save :: writeMessage2Screen = .false.
logical, save :: useLogging = .true.
!> Callback routine invoked upon any mess/err (i.e. SetMessage)
procedure(mh_callbackiface), pointer :: mh_callback => null()
contains
!> Sets up the output of messages. All three formats are optional
!! and can be used in any combination.
subroutine SetMessageHandling(write2screen, useLog, lunMessages, callback, thresholdLevel)
logical, optional, intent(in) :: write2screen !< Print messages to stdout.
logical, optional, intent(in) :: useLog !< Store messages in buffer.
integer, optional, intent(in) :: lunMessages !< File pointer whereto messages can be written.
integer, optional, intent(in) :: thresholdLevel !< Messages with level lower than the thresholdlevel
!< will be discarded.
procedure(mh_callbackiface), optional, pointer :: callback
if (present(write2screen) ) writeMessage2Screen = write2screen
if (present(lunMessages) ) lunMess = lunMessages
if (present(useLog) ) useLogging = useLog
if (present(callback) ) mh_callback =>callback
if (present(thresholdLevel) ) thresholdLvl = thresholdLevel
end subroutine SetMessageHandling
!> The main message routine. Puts the message string to all output
!! channels previously set up by SetMessageHandling
subroutine SetMessage(level, string)
integer, intent(in) :: level !< One of: LEVEL_(DEBUG|INFO|WARN|ERROR|FATAL).
character(len=*), intent(in) :: string !< Complete message string.
integer :: levelact
levelact = max(1,min(max_level, level))
! Optional callback routine for any user-specified actions (e.g., upon error)
if (associated(mh_callback)) then
call mh_callback(level) ! AvD: in future, possibly also error #ID
end if
end subroutine
integer function getMessageCount()
getMessageCount = messagecount
end function
integer function GetMessage_MH(imessage, message)
character(len=200) :: message
integer, intent(in) :: imessage
message=messages(imessage)
GetMessage_MH = levels(imessage)
end function
subroutine resetMessageCount_MH()
messageCount = 0
end subroutine
integer function getMaxErrorLevel()
getMaxErrorLevel = maxErrorLevel
end function
subroutine resetMaxerrorLevel()
maxErrorLevel = 0
end subroutine
subroutine message1string(level, w1)
character(*) :: w1
integer :: level
integer :: l1
character(600) :: rec
rec = ' '
l1 = max(1, len_trim(w1))
write (rec(1:), '(a)') w1(:l1)
call setMessage(level, rec)
end subroutine message1string
!-- Error interfaces ----------------------------
subroutine error1char(w1)
character(*) :: w1
call mess(LEVEL_ERROR, w1)
end subroutine error1char
end module MessageHandling
Arjen,
You posted this in the Windows forum, but...
Would you please show me the command line you used and the output of an "ifort -V" command? Do you really mean IA-64 (Itanum) or perhaps did you mean "Intel 64" (x64)?
Arjen_Markus
Hi Steve,
oops, I did not realise that there is a separate Linux forum.
Anyway, the command line was simply:
ifort -g -o name.o name.f90
I do not have access to the machine right now (that will have to wait until thursday), but
I did use the option "ia64" instead of "ia32" to set up the ifort environment variables.
Arjen
Ok. When you get the output of the ifort -V command, please supply it.
Are you targeting Itanium systems?
Arjen_Markus
Hi Steve,
the output from ifort -V is:
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.0 Build 20090131 Package ID: l_cprof_p_11.0.081
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
(this is after issuing: . ..../ifortvars.sh ia64)
I noticed there are three possible targets: ia32, ia64 and intel64. I guess I should be using intel64, as we
are not targeting Itanium perse.
Arjen
Yes, you should be using "intel64", but in 11.0 ifortvars.sh didn't take an argument so you got whichever platform you specified by the path to ifortvars.
Can you try a more current compiler?
Arjen_Markus
Really? On my system, if I do not specify an argument (ia32, ia64 or intel64) it complains about an unknown
platform.
I will see if we alreadyhave 11.1 installed somewhere.
Arjen
Sorry - my error. You are correct. I am puzzled then that specifying ia64 would get you Intel 64.
Arjen_Markus
I had Intel Fortran 11.1 installed and this seems to be doing fine.
Arjen
Ok, thanks for letting us know.
