29605 Discussions
Interoperability: Fortran Calling C and passing and integer
gandresr
I am trying to run a C function from a Linux shared library (.so) from Fortran. The function in C receives an integer number from the Fortran program. I am not getting the right result in C. There seems to be a type error that I can't identify. I am creating an abstract interface following the syntax for interoperability established here
Function in C:
int print_number(int n)
    printf("Hello world! %d\n", n);
    return 0;
Function in Fortran
! Interface with shared library
abstract interface
    !% Simulation
    integer function print_number(number)
        use, intrinsic :: iso_c_binding
        implicit none
        integer(c_int), value :: number
    end function print_number
end interface
The output when calling print_number(2):
Hello world! 734920112
I am attaching the files to reproduce the error. First, execute `./compile.sh`, then `./run_test
I would appreciate it a lot if someone could point out what I am doing wrong.
Thanks!
Khalik_K_Intel
Thank you for contacting Intel Support.
As specified earlier by Arjen_Markus, you are not using "bind(C)" attribute for the abstract interface.
This is why you are getting wrong results in you application.
BIND is the language-binding-spec attribute which in this case should be used to specify the interface of an external interoperable procedure.
For more info please see: https://www.intel.com/content/www/us/en/develop/documentation/fortran-compiler-oneapi-dev-guide-and-reference/top/compiler-reference/mixed-language-programming/standard-tools-for-interoperability/bind.html
So, the only thing you need to change is to modify the following line in "interface.f90":
To:     integer function print_number(number) BIND(C)
I check the result on my end and it is as expected:
$ . compile.sh
$ ./run_test
Hello world! 2
$ ./run_test
Hello world! 2
$ ./run_test
Hello world! 2
Hope that this helps.
Khalik.
Arjen_Markus
Your code is loading the library and then retrieving a pointer to the function. So it is a bit more complicated than what you sketched. I do not see anything obviously wrong, but you do not use the "bind(C)" attribute for the abstract interface. I am sure this is not really the problem, but it might be cleaner. Another thing: you pass in the literal number 2 (default integer), but the function expects an integer of type c_int. You should try with 2_c_int or something similar.
Khalik_K_Intel
$ . compile.sh
$ ./run_test
Hello world! 2
$ ./run_test
Hello world! 2
$ ./run_test
Hello world! 2
Khalik.
andrew_4619
abstract interface
    function print_number(number) bind(C)
        implicit none
        integer(c_int) :: print_number ! note function type also
end interface
Khalik_K_Intel
Has your issue been solved or do you have any questions on this?
Khalik.
Khalik_K_Intel
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
