29279 Discussions
Invoke ancester's method of the same name while overriding
Blane_J_
Here's the sample:
module mod1
    implicit none
    type, abstract :: tp1
        private
        character(5) :: var1 = "abcde"
    contains
        private
        procedure, public, pass :: sub1
    end type tp1
    contains
    subroutine sub1(this)
        implicit none
        class(tp1), intent(in) :: this
        print*, this % var1
    end subroutine sub1
end module mod1
module mod2
    use mod1, only: tp1
    implicit none
    type, extends(tp1) :: tp2
        private
        character(5) :: var2 = "12345"
    contains
        private
    end type tp2
    contains
        implicit none
        class(tp2), intent(in) :: this
        ! Is it possible to invoke sub1 of ancestor tp1 here and how to do that ?
        print*, this % var2
    end subroutine sub1
end module mod2
So is it possilbe that procedure sub1 of the child class tp2 invoke ancester's sub1 while override it ? Thanks for any help.
DavidWhite
Valued Contributor II
Two issues, I think:
1. sub1 of the ancestor is not visible
2. can't have two routines of same name.
I think in mod2, the use statement for mod1 needs to include sub1, with the rename option to give it a new name to use within mod2
Blane_J_
Thanks David. I think it is more convenient to use type-bound procedure rather than invoke it directly: sub1 of the ancestor impliments part of the job and in decendent, we inherit the first part and accomplish the remaining part in addition.
In C# there is a key word "base" which is used to invoke ancestor's public method directly within decendent, here in Fortran I wonder if there's any way to impliment the same functionality.
FortranFan
@Blane J.,
In Fortran, an object instance of an extension type (say e) can reference the type it extends (say b) by the type name e.g., ..%b.. but not when the base type is ABSTRACT.  However the components and procedure bindings of the base ABSTRACT type can be referenced directly (notwithstanding any considerations of PRIVATE/PUBLIC attributes with visibility in a given scope).
Given what you show in the original post, an option you may to consider is generic bindings for your 'sub' and think of ways you can relate to such bindings when it comes to disambiguation, say for example add a 'dummy' dummy argument to.the 'sub' binding in the base ABSTRACT type named 'base' which does your 'part of the job' when the value is true!
module mod1
   implicit none
      private
   contains
      private
      procedure, pass :: sub1
      generic, public :: sub => sub1
   end type tp1
contains
   subroutine sub1(this, base)
      implicit none
      logical, intent(in) :: base
      if ( base ) then
         print*, this % var1
      else
         ! handling elided
      end if
   end subroutine sub1
end module mod1
module mod2
   use mod1, only: tp1
   implicit none
      private
   contains
      private
      procedure, pass :: sub2
      generic, public :: sub => sub2
   end type tp2
contains
   subroutine sub2(this)
      implicit none
      call this%sub( base=.true. )
      print*, this %var2
   end subroutine sub2
end module mod2
   use mod2, only : tp2
   type(tp2) :: foo
   call foo%sub()
end
Blane_J_
So the point is about the ABSTRACT affair. The GENERIC solution is feasible and appreciate your help, FortranFan.
