Is Shared Library same as DLL
mkhwang9
I wonder if Shared Library is exacltly same as DLL in terms of its function. In Windows system, DLL is loaded when I readlly need it. That is, it is not automatically loaded when calling program is started(invoked). Is it same with Shared Library ? Acutally, I made a small program which may call or may not call - depending on the flow logic- a subroutine that is made as shared library. I am not sure if the shared library is always loaded into memory or only loaded when it is initally called. Any comment would be very much appreciated.
Moonkyu
In the Linux world, it's called a "shared object" (.so), but yes, it's very much like a DLL. Unlike a DLL, you can link directly to a .so and don't need a separate "export library".
However, even on Windows, a DLL is loaded automaticlaly when the program starts, whether or not you call any routines in it. The Microsoft linker does have a "delayed load" feature which you can enable, where a "stub" is linked in that dynamically loads the DLL when the routine is called. That behavior is not the default. I don't know if Linux has something similar.
