Is it a compilation error ?
coolweather
I have the follwoing solution structure
1. C main project
calls Fortran interface subroutines
[bash]int main(int argc, char **argv) {
interface1_(&x,&y);
interface2_(&x,&y);
}[/bash]
2. Fortran static lib project (libinterface.a)
calls fortran subroutines from a fortran module
[bash]subroutine interface1(x,y)
    use amodule
    call test1(x,y)
end subroutine
subroutine interface2(x,y)
    use amodule
    call test2(x,y)
end subroutine[/bash]
3. Fortran static lib project (libamodule.a)
a module that contains some computation routines
[bash]module amodule
    implicit none
contains
subroutine test1(x,y)
end subroutine test1
subroutine test2(x,y)
end subroutine test
end module[/bash]
Now I comment the subroutine 'test2', recompile libamodule.a, and when I'll compile libinterface.a (which reference to test2 subroutine), it will be successfully compiled. The compiler does not detect that libinterface.a references on the subroutine that does not exist! Is it an error ?
No, it is not an error. If the compiler does not see test2 in a module it assumes it is an external procedure. You would see an error when you linked the program.
Ron_Green
I could take a look at this, but what you're doing in the main program is not good. You should never rely on name decoration with the underscore like you're doing. Firstly, g77 wouldn't compile this - it uses 2 underscores. And there is no guarantee that we might someday do some other name decoration.
Why aren't you using an interface for interface1 and interface2? Or put them into a module and USE the module in your main program? You do know there is a -gen-interfaces compiler option that could be used to compile the source file with interface1 and interface2 to automatically generate the interfaces.
Aside from the benefits of making the code more readable, a module or interface could prevent some potential unnecessary data copy-in copy-out for the arguments. It enhances code maintenance and performance. It's a win-win as they say.
I'll take a look at this later today. What compiler version are you using?
ron
I would suggest using BIND(C) to make sure that naming is consistent. That would remove the trailing underscore.
coolweather
Thank you, Ron!
I did not know about an interface option, it looks very promising, could you give me the reference/link to read more about it, please ?
I use 11.1 (cluster) and 12 (local) versions of compilers.
Could you advice me the other thing I cannot resolve since several days: IDB does not see breakpoints in my code, and it skips them. But if I do line by line from the start I can attain these lines without problem.
What may be the reason of such unresolved breakpoints? Something wrong in the code that compiler does not understand? but I cannot find what exactly it is...
Thank you for your help!
mecej4
About the breakpoints: if you compiled the code with any optimizations turned on (whether you specified such options explicitly or they are turned on in your default configuration or in your project) the compiled code will probably not execute in the same order as your source statements.
For instance, the compiler can turn nested DO loops inside out. Stepping through such source lines can be disconcerting if you are not used to this behavior. In fact, you can press F10 or F11 and the cursor can go back several lines.
Anyway, we need a more complete and specific description of the debugger problem.
coolweather
debugger options :
[bash]FORT        = ifort -g3 -O0 -fpp -threads -traceback -w -C -c
LINKER      = ifort -static -nofor_main -o
FLAGS       = -I/usr/local/include -I/usr/include
C           = icc -g3 -O0 -fpp -traceback -w -C -c[/bash]
the structure of the solution as descibed above :
main in C that calls fortran subroutines via fortran interface project
problem :
debugger skips any breakpoint (warning: unresolved breakpoint)
please, let me know what other information do you need ?
mecej4
One explanation, which you can easily rule out by checking: sometimes, one has two sets of sources: e.g., a back up set and a working set, in different directories. If the working set is modified and compiled, but the debugger us told to open up the source files from the backup set, it is going to be very confusing when it uses incorrect mapping from program counter to line number.
coolweather
I did not touch working sets at all. I use makefile compilation which indicates the paths to source code.
is there other reasons to have unresolved breakpoints ?
jimdempseyatthecove
Try placing a break point in your C main, then step into the Fortran code. Does the source window show the correct position?
If Step Into performs a Step Over then this is an indication that debug information was stripped from the Fortran code (example, linker settings set to remove debug info).
If Step Into goes into (something) but the source window does not reflect the correct position in the Fortran file then this indicates one of
a) The source file viewed is not the one used for build (what mecej4 was referring to).
b) The object file linked was not built with the source file viewed
c) The (a) preprocessor or Fortran INCLUDEbunged up the line numbers
If the Step Into steped correctly, try placing a break point on the next statement. Does the break point set? If so, does Continue run to the break point?
Jim Dempsey
coolweather
any breakpoint in main C is unresolved breakpoint (debugger show a warning message, and the line is red highlighted in eclipse)
thus if I set some breakpoints in main C , all they will be skiped.
if I set a breakpoint in my fortran project, debugger stops at this breakpoint
jimdempseyatthecove
now>>if I set a breakpoint in my fortran project, debugger stops at this breakpoint
earlier>>debugger skips any breakpoint (warning: unresolved breakpoint)
I'm confused - conflicting statements.
also>>any breakpoint in main C is unresolved breakpoint
then main C is not compiled with debug informaton (or linker stripped it out).
One of the purposes of breaking in main C, then stepping into the Fortran function (which may require you to step in via the dissassembly window(if stepping in from source window does not work)), is, when using the dynamic load library the step into (at some point) will (on first call)trap into theO/Sto locate and load the library, then continue the step into in the called function. At this point, it may become evident that the library loaded is not the library you think is being loaded. To aid this, temporarily adda statement just after the entry point thatdoessomething innoucous, but is clearly seen in source and dissassembly (and is not inlined)
subroutine foo
! data declarations
! first code statement
X = DRAND(0) ! call external function, store in existing variable
! original code follows
IIF you can step intousing sorce window, restart and step into using Dissassembly window. In either case, after the
library loads, you will notice one of the following
a) source without X = DRAND(0) is shown
b) source with X = DRAND(0) is shown *** however,dissassembly code does notcontain calldrand...
c) source with X = DRAND(0) is shownand call drand is present
d) no sorce is shown call drand is NOT present
e) no sorce isshown call drand is present
What do you observe?
Jim Dempsey
coolweather
I found a very strange case :
when i is global variable
[bash]module m
integer i
subroutine sb...
    DO i=1,n
        print *, i
        some_array(i) =  ...
    END DO
end subroutine sb
end module[/bash]
the function 'print' will print the correct values, while in Variables or Expression windows of Eclipse i=16843009
it means that the next breakpoint step the index i will be out of the range, and breakpoint become unresolved
if I declare the variable i as a local one the breakpoint is skipped too
Do you know what is the reason ?
coolweather
Jim, sorry for this ambigous phrases.
I tested different cases, and they gave different results, and I could not find any logic between them
at this stage, I took an empty C project, created only main function and called my fortran subroutine stored in static library module
this way I can be concentrated only on errors from Fortran code
fortran module was compiled with debug info and linked with static option to main C object file
the options of compilation and linking you can find at the beginning of this topic, as well as the struction of my projects.
as you've probably read my previous message, I found that there is something wrong with global module variables, because the debugger does not see their right values when it is stopped in some subroutine.
it was one of the cases when the breakpoints became unresolved, perhaps there are other cases that I did not find yet.
jimdempseyatthecove
When compiling with optimizations enabled, your integer i might get hoisted into a register. Your print *,i will work fine, but examining the memory location of i becomes meaningless.
Note, at the end of the DO i= loop, the register copy of i should be copied back into the global i. However, if the whole program is visible to the compiler and i is not used excepting for in this subroutine, then the loop control variable (in register) i might not get copied into the global (module) variable i.
Note 2, if the copy from register i to module i is performed after end of loop, it won't be copied back at break point (say on the print). There is where you will see the discrepancy. In this case, the debugger, while in scope of DO i loop should indicate i is a register variable. The memory watch window (set outside the loop) will observe the global i (not the registered copy of i) so you will either see it as load image initialization or after termination of DO loop, whichever occured last. If you want to track i during execution, call a dummy external routine (not visiable to the compiler optimization). You can also compile with OpenMP enabled, then add:
DO i=1,n
!$OMP FLUSH (i)
Note, this is a convienence for debugging and not pertinant for the execution of your do loop unless i is used as a progress indicator by some other thread, and in which case you will need something like !$OMP FLUSH (i) or attribute the variable i as volatile. Note, the !$OMP FLUSH (i) may be a better choice than volatile or add a integer, volatile ::iProgress
and then use
iProgress = i
in your DO loop
Jim Dempsey
coolweather
Thank you, Jim, for your explanation!
the fact that the code is compiled without optimization enable, the options -g3 -O0 and -static for linking are used.
and I switched off the MPI parts
I've replaced my global module i by a local variable, and this does not solve the problem with unresolved breakpoints
The fortran module has thousands of arrays to allocate as global variables with SAVE option, the debugger steps between neigbour statements are unreally very long (15 sec and more). is it possible that the debugger can not handle such volumes of variables ? or does SAVE option disturbe the debug process ?
jimdempseyatthecove
When single stepping across
arrayA = arrayB
while compiled with array bounds checking enabled (an option in the Debug and/or release builds) then each element of arrayA = arrayB will be bounds tested. You may want to turn off bounds checking (for those source files tested at least once with bounds checking and retest later when varying a parameter that might cause an array indexing error).
Note,
arrayA(i) = (expression)
will get set eventhough i may get registerized.
Also note, vectorization might store multiple sequences at once
arrayA(i+1) = (expression')
arrayA(i+2) = (expression'')
arrayA(i+3) = (expression''')
When data is aligned properly and the compiler can reliably compute expression', expression'' and expression '''
Jim Dempsey
I have this error when I try to run an executable.
"filename truncated to thirty one characters"
someone who can help me?
mecej4
If I may be permitted to be facetious, I would offer the following program as a candidate:
[fortran]print *,"filename truncated to thirty one characters"
end
[/fortran]
If you want a more helpful answer, you should give more particulars about your program.
Georg_Z_Intel
I see that (one of) your question(s) still hasn't been answered yet.
I've tried to reproduce the problem reported (BPs in C source file cannot be set). However, I've not seen anything like that.
Instead I'd like to provide a working example based on your previous posts for verification:
main.c:
[cpp]int main(int argc, char **argv) {
    int x = argc;
    int y = argc / 2;
    interface1_(&x,&y);
    interface2_(&y,&x);
}[/cpp]
module.f90:
[fortran]module amodule
    implicit none
    contains
    integer x, y
        write (*,*) x, y
    integer x, y
        write (*,*) x, y
    end subroutine test2
end module[/fortran]
interface.f90:
[fortran]subroutine interface1(x,y)
    use amodule
    integer x, y
    call test1(x,y)
end subroutine
    use amodule
    integer x, y
    call test2(x,y)
end subroutine[/fortran]
Compile, using ICC & IFORT (both should have same version):
[bash]ifort -g3 -O0 -fpp -threads -traceback -w -C -c module.f90
ar rcs libmodule.a module.o
ifort -g3 -O0 -fpp -threads -traceback -w -C -c interface.f90
ar rcs libinterface.a interface.o
icc -g3 -O0 -fpp -traceback -w -C -c main.c
ifort -static -nofor_main -o main_fort main.o -L. -linterface -lmodule
icc -static -o main_c main.o -L. -linterface -lmodule -lifcore[/bash]
I've tested both 12.1 Update 6 & 11.1 Update 9.
Testing the binaries, you'll see this:
[bash]$ ./main_c
           1           0
           0           1
$ ./main_fort
           1           0
           0           1
[/bash]
Now start IDB. I'll be using 12.1 Update 6 here but also tested with the older 11.1 version.
Load either main_c or main_fort and set a BP for symbol main. Once the debuggee was executed you'll stop there and soruce file main.c is shown.
In my case I was able to set BPs in all C & Fortran source files at the same time, and actually stopping there:
Maybe you can try the exact same steps and let me know if something does not work for you or what you're doing differently.
Regarding your other problem (evaluating variable "i") you might use the provided code and extend it to reproduce what you're seeing. Please don't forget to specify exactly what you're doing with the debugger to evaluate it (were you set BPs, continue, step, etc.). The context during evaluation is critical for the results of evaluations and clarifies whether this is expected behavior (by language standard) or a problem (e.g. debug information).
@Jim, the DWARF debug standard defines "location expressions" that can be both memory or registers. The presentation is transparent for the user, which means it's not relevant where a variable "i" is stored (permanently or even temporarily). Thanks the debug information the debugger always reads from the correct location, depending on the current PC.
The only case where the debugger might fail to handle a location expression is for variables being optimized away. However, that's not the case here -> #15.
Georg Zitzlsberger
