29375 Discussions
Is it possible to call C# directly from Fortran?
Sherry_Ummen
I know its possible to call C# from Fortran via C++. but was wondering do we some direct way to do it with the new intel compiler 2015?
andrew_4619
there are lots of threads on this subject in the forum if you do a search.....
The most straightforward way is to have C# build a regular (not COM or Automation) DLL. You'll then need to figure out what the C# code is looking for in its arguments. Not all C# argument types can be passed from Fortran.
jimdempseyatthecove
A sketch of Steve's advice is as follows:
// C# .dll
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
//using YourOtherStufv;
namespace YourDLL
  public class YourDLLAsApp
    public static void lauchYourApp(IntPtr ptr) // you figure out args you want
      Console.WriteLine("We are now inside YourDLLAsApp (C# managed)");
! your interfaces
module mod_Interfaces
interface
  !  void lauchYourApp(void* ptr1)
  SUBROUTINE lauchYourApp(ptr) BIND(C, name="lauchYourApp")
    use, intrinsic :: ISO_C_BINDING
    use mod_Interfaces
    procedure(YourProcedure), pointer :: ptr
  end SUBROUTINE lauchYourApp
end interface
end module mod_Interfaces
! your program
PROGRAM YourProgram
  use mod_Interfaces
  call lauchYourApp(SomeFortranRoutineOrType)
end program YourProgram
The code is untested, merely a sketch.
Jim Dempsey
