Is it safe to associate a global pointer to a local target variable?
S__MPay
If I define a local target variable inside a subroutine, then associate a global pointer to that value, is it safe to use the pointer to access that value outside of subroutine or the data can be overwritten and changed unexpectedly?
Arjen_Markus
No, if it is a local variable, it will disappear upon return from the routine. The exception is if that variable has the SAVE attribute.
What is the reason you want to do that? There are probably better methods, depending on the purpose.
Arjen_Markus
S__MPay
As you know type components cannot be a target, i.e. property of a class cannot be a target.
on the other hand I need properties of numerous objects to be pointing to that specific property.
My temporary solution was to make a target in a subroutine and have the pointers to associated with that value.
jimdempseyatthecove
Can the specific property in question .NOT. be an encapsulated property of some other object type? IOW all objects requiring said common property have pointers to the shared property.
Jim Dempsey
IanH
Component definitions cannot include TARGET, but any subobject of an object that has the target attribute is also a target.
Something associated with a pointer component is also always a target.
Perhaps you could elaborate further about the background to your question.
S__MPay
jimdempseyatthecove wrote:
...Can the specific property in question .NOT. be an encapsulated property of some other object type?...
Dear Jim encapsulation is not a must. I am thinking to use a variable outside of target definition inside class module to workaround this. Maybe then even add a pointer type component associated with that variable inside type definition if needed.
ianh wrote:
...Perhaps you could elaborate further about the background to your question.
So my project has a Database class which keeps all the model information including an array of materials available.
We have numerous (say one million) elements but we have a few material types.
Each element has to be associated with a material.
I don't want to have one million instances of materials. So in my design each element has a material pointer which is associated with one of the materials in the Database%materialsArray.
Currently my only solution is to define materialsArray  outside of the Database type as a target array.
IanH
Just give the Database object the TARGET attribute.
TYPE :: material_type
END TYPE material_type
TYPE :: database_type
  TYPE(material_type) :: materials(nm)
END TYPE database_type
TYPE :: element_type
  TYPE(material_type), POINTER :: material
END TYPE element_type
TYPE(database_type), TARGET :: Database
TYPE(element_type) :: Elements(ne)
Elements(ie)%material => Database%materials(im)
S__MPay
I see, Thanks;
but the database is pretty big and contains many other types, and large arrays.
Making them all target won't affect calculation performance?
IanH
I don't know, as I don't know your code.  But I rather doubt it.
