29487 Discussions
Is there a standard-compliant alternative to the Q control edit descriptor?
OP1
New Contributor III
The Q control edit descriptor is a nifty feature... but it's not standard-compliant.
A standard-compliant workaround I can think of is to use a loop of non-advancing IO read statements with EOR to catch the end of the record... but this is rather unwieldy...
Any other suggestions?
PROGRAM P
IMPLICIT NONE
INTEGER :: I
CHARACTER(LEN=1) :: S
OPEN(FILE='Test.txt',UNIT=10,FORM='FORMATTED',STATUS='REPLACE')
WRITE(10,FMT='(A10)') 'A        1'
REWIND(10)
READ(10,'(A1,Q)') S,I
WRITE(*,'(A,I4)') S,I
CLOSE(10)
END PROGRAM P
Steve_Lionel
I am not sure what you really want to do here, but I'd lean towards this approach:
PROGRAM P
IMPLICIT NONE
INTEGER :: I
CHARACTER(100) :: LINE
REWIND(10)
READ (10,'(A)') LINE
READ(LINE,'(A1)') S
I = LEN_TRIM(LINE)-1
CLOSE(10)
END PROGRAM P
