29342 Discussions
Is there any way to utilize BLAS with symmetry for high rank tensor/array
AlphaF20
  I came cross a type of tensor contraction with symmetry in individual tensor(s). I would like to know if there is a way to utilize such symmetries in BLAS.
  For instance, for a tensor contraction
A[a,b] * B[b,c,d] = C[a,c,d]
 where the Einstein summation rule was assumed, repeated index, b, stands for summation. i.e., \sum_b in the above equation. Tensor/array A,B,C are all real. The tensor/array b has a symmetry
B[b,c,d] = B[b,d,c]
which leads to
C[a,c,d] = C[a,d,c]
In BLAS, there are some subroutines about symmetric matrix, but not higher rank tensor/array as far as I know. Is there any way to utilize the above symmetries in DGEMM or any other subroutines?
 I heard to first do loops over indices c and d, then do DGEMM with array with fewer indices. If I define new arrays
B_small(:) = B(:,c,d), C_small(:) = C(:,c,d)
that would take a bit time (I think I tested the wall time at some stage). Hence, I would like to know any efficient solution. My attempt code is following
Program blas_symm_tensor
  Use, Intrinsic :: iso_fortran_env, Only :  wp => real64, li => int64
  Implicit None
  Real( wp ), Dimension( :, :    ), Allocatable :: a
  Real( wp ), Dimension( :, :, : ), Allocatable :: b
  Real( wp ), Dimension( :, :, : ), Allocatable :: c1, c2, c3, c4, c5
  Integer :: na, nb, nc, nd, ne
  Integer :: la, lb, lc, ld
  Integer( li ) :: start, finish, rate, numthreads
  Write( *, * ) 'na, nb, nc, nd ?'
  Read( *, * ) na, nb, nc, nd
  ne = nc * nd
  Allocate( a ( 1:na, 1:nb ) )
  Allocate( b ( 1:nb, 1:nc, 1:nd ) )
  Allocate( c1( 1:na, 1:nc, 1:nd ) )
  Allocate( c2( 1:na, 1:nc, 1:nd ) )
  Allocate( c3( 1:na, 1:nc, 1:nd ) )
  Allocate( c4( 1:na, 1:nc, 1:nd ) )
  Allocate( c5( 1:na, 1:nc, 1:nd ) )
  ! Set up some data
  Call Random_number( a )
  Call Random_number( b )
  ! symmetrize tensor b
  do la = 1, na
    do lc = 1, nc
      do ld = lc+1, nd
         b(la,lc,ld) = b(la,ld,lc)
      enddo
    enddo
  enddo
  Call System_clock( start, rate )
  c1 = 0.0_wp
  do ld = 1, nd
    do lc = 1, nc
      do lb = 1, nb
        do la = 1, na
          c1(la,lc,ld) = c1(la,lc,ld)  + a(la,lb) * b(lb, lc, ld)
        enddo
      enddo
    enddo
  enddo
  Call System_clock( finish, rate )
  Write( *, * ) 'Time for loop', Real( finish - start, wp ) / rate
  c2 = 0.0_wp
  do ld = 1, nd
    do lc = 1, ld
      do lb = 1, nb
        do la = 1, na
          c2(la,lc,ld) = c2(la,lc,ld)  + a(la,lb) * b(lb, lc, ld)
        enddo
      enddo
    enddo
  enddo
  do ld = 1, nd
    do lc = ld+1, nc
      do la = 1, na
        c2(la,lc,ld) = c2(la,ld,lc)
      end do
    enddo
  enddo
  Write( *, * ) 'Time for symmetric loop', Real( finish - start, wp ) / rate
  c3 = 0.0_wp
  do ld = 1, nd
    do lc = 1, ld
       Call dgemm( 'N', 'N', na, 1, nb, 1.0_wp, a , Size( a , Dim = 1 ), &
                                            b(:,lc,ld) , Size( b , Dim = 1 ), &
                                            0.0_wp, c3, Size( c3, Dim = 1 ) )
    enddo
  enddo
  do ld = 1, nd
    do lc = ld+1, nc
      do la = 1, na
        c3(la,lc,ld) = c3(la,ld,lc)
      end do
    enddo
  enddo
  Write( *, * ) 'Time for symmetric dgemm', Real( finish - start, wp ) / rate
  ! Direct
  Call dgemm( 'N', 'N', na, ne, nb, 1.0_wp, a , Size( a , Dim = 1 ), &
                                            b , Size( b , Dim = 1 ), &
                                            0.0_wp, c4, Size( c4, Dim = 1 ) )
  Write( *, * ) 'Time for straight dgemm', Real( finish - start, wp ) / rate
  c5 = 0.0_wp
  do ld = 1, nd
    do lc = 1, ld
       Call dgemv( 'N', na,  nb, 1.0_wp,  a, na, b(1,lc,ld), 1, 0.0_wp,  c5, 1 )
    enddo
  enddo
  do ld = 1, nd
    do lc = ld+1, nc
      do la = 1, na
        c5(la,lc,ld) = c5(la,ld,lc)
      end do
    enddo
  enddo
  Write( *, * ) 'Time for symmetric dgemv', Real( finish - start, wp ) / rate
  do la = 1, na
    do lc = 1, nc
      do ld = 1, nd
         if ( dabs(c1(la,lc,ld) - c2(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c2', la,lc,ld, c1(la,lc,ld) - c2(la,lc,ld)
         endif
         if ( dabs(c1(la,lc,ld) - c3(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c3', la,lc,ld, c1(la,lc,ld) - c3(la,lc,ld)
         endif
         if ( dabs(c1(la,lc,ld) - c4(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c4', la,lc,ld, c1(la,lc,ld) - c4(la,lc,ld)
         endif
         if ( dabs(c1(la,lc,ld) - c5(la,lc,ld))  > 1.e-6 ) then
           write (*,*) '!!! c5', la,lc,ld, c1(la,lc,ld) - c5(la,lc,ld)
         endif
      enddo
    enddo
  enddo
End Program blas_symm_tensor
I got different number in resulting array c3 (DGEMM) and c5 (DGEMV)
Thank you very much!
Steve_Lionel
This is not a Fortran compiler question - better asked in Intel® oneAPI Base Toolkit - Intel Community , which is where MKL hangs out.
Steve_Lionel
AlphaF20
Thanks you very much. I will post there.
