29273 Discussions
Is there anyway to stop the DEFTOFD tool from creating the $_win32 variable
Ray_R_1
Hello, I have a large fortran project with 14 resource files, each with its own header file (all with different names). When I use the deftofd tool to convert the .h files to .fd files, the deftofd tool creates a $_win32 variable and sticks it in each .fd file, which causes a problem when I include more than one .fd file in a subroutine, is there any way to tell the tool not to create that variable? And what is it used for anyways?
That's a very good question. I was not aware it was doing this, but I see that it is. No idea what it is used for - I will ask. For now, I suggest that you put each INCLUDE of the .fd files in a separate module and USE the module. This will avoid problems with the duplicate symbol, as long as you don't reference it. Issue ID is DPD200234030.
Ray_R_1
Thank you. As a work around for now I have written my own translator for the h to fd files. Not pretty but works.
I am still interested in what that variable is?
Udit_P_Intel
I believe this variable just specifies that the current operating system is WIN32. There should be a command line switch which can either enable or disable this behaviour. We are looking at this.
Best!
-Udit
Udit_P_Intel
More investigation reveals that using the /u switch disables the creation of $_WIN32 . Using a recent version of deftofd on a Win32 machine, I find the following: [bash]x:/cq/testing$ cat whizzy.h end x:/cq/testing$ deftofd whizzy.h temp.fd x:/cq/testing$ cat temp.fd ! ! temp.fd generated from whizzy.h ! integer, parameter :: $_WIN32 = 1 x:/cq/testing$ deftofd whizzy.h temp.fd /u x:/cq/testing$ cat temp.fd ! ! temp.fd generated from whizzy.h ![/bash] I think all you need is /u upon invoking deftofd. Best! -Udit
Note that in Visual Studio, deftofd is invoked as a custom build step for the .h file. You can edit the command used there to add the /u.
Ray_R_1
Thank you, is there any documentation showing what the command options are for deftofd?
There's no user documentation on options. We're going to change deftofd to not put out that symbol.
The definition will be removed in an update later this year (October would be my guess.)
