29278 Discussions
Is type-binding procedure can't be "function"?
slsfortran
Can only be "subroutine"?
IanH
Quoting - slsfortran
Thanks, IanH.
The getNodeDOF function is the default as PUBLIC according to f2003 standard.
I try your advice, however, it gets the same error again. So, I think.....pahaps there are other reasons.
I think the private statement on line 7 of node.f90 would change the default accessibility for entities in module CNode (I erroneously said module Node in my previous post but there is no such thing - apologies if this was confusing). I believe this is separate to the visibility of the various components and type bound procedures within the type Node, which is still public by default.
Changing line 148 of NodeManage.f90 from
i = getNodeDOF(this%mNode(1)) ! where you are trying to access the module procedure
to
i = this%mNode(1)%getNodeDOF() ! where you are accessing the type bound procedure
results in both files compiling for me without error using 11.1.051.
An alternative would be to add the PUBLIC attribute to getNodeDOF in module CNode (again, at module level). Then you could retain the former function call syntax. But that's a bit clunky, and anway, it causes 11.1.051 to ICE :(.
TimP
Another example posted on forum recently indicates there may be a bug in this area.
Steven_L_Intel1
Type-bound procedures can be functions - please provide an example of what doesn't work for you.
slsfortran
The Example is not a complete program (only two modules). However, it can explain the problem. When compile the Example, the error message is "error #6404: This name does not have a type, and must have an explicit type. [GETNODEDOF]".
If convert the Function to Subroutine, everything is OK.
Why?
IanH
The getNodeDOF module procedure (as opposed to its type bound name) in module Node is private (therefore that name in getStrNumCell must refer to "something else", whatever it is it has not been given a type and therefore an error occurs). Perhaps try something like "this%mNode(1)%getNodeDOF()".
Consider the case of the procedure name and binding name being different:
TYPE Node
CONTAINS
PROCEDURE :: getNodeDOF => some_really_bizarre_name_private_to_the_module
END TYPE Node
Subroutines don't have a type, so you don't need to/can't explicitly declare their type. I suspect (hope?) you might have had issues linking though. A nice feature for IVF would be a mandatory "no explicit interface visible for this procedure call" warning - even if just to annoy all those who insist on not using modules :)
slsfortran
Quoting - IanH
TYPE Node
CONTAINS
END TYPE Node
Thanks, IanH.
IanH
Thanks, IanH.
to
