Issue with !$OMP CANCEL construct
OP1
New Contributor III
Using the latest ifx compiler (2026.0.0) on Windows 11 in Debug mode, the following code hangs fairly regularly (even when running with a modest number of threads):
PROGRAM P
USE OMP_LIB
IMPLICIT NONE (TYPE, EXTERNAL)
INTEGER :: I, SUM, VERSION
! Check if the cancellation feature is activated (a requirement for the CANCEL construct to work).
IF (.NOT. OMP_GET_CANCELLATION()) THEN
    WRITE(*, *) 'The CANCEL feature is not activated. Set the environment variable OMP_CANCELLATION to true.'
    STOP
END IF
! This will fail (that is, the code will hang) randomly, when running the code
! multiple times.
!$OMP PARALLEL
    WRITE(*, *) OMP_GET_THREAD_NUM(), '/', OMP_GET_NUM_THREADS()
    !$OMP DO REDUCTION(+:SUM)
        DO I = 1, 10000
            SUM = SUM + I
            !$OMP CANCEL DO IF (I == 5)
        END DO
    !$OMP END DO
!$OMP END PARALLEL
WRITE(*, *) SUM
END PROGRAM P
I do not see any restrictions associated with the use of the REDUCTION clause with CANCEL constructs in the OpenMP specification. It does look like a bug.
