29640 Discussions
Issue with SELECT CASE and null CASE block
jimdempseyatthecove
In the following code EDIT: using ifort
    J = FP_CLASS(pTether%pFiniteSolution%ELBD)
  SELECT CASE (J)
    CASE (0)
    call DOSTOP('TNSMKS FOR_K_FP_SNAN')
    CASE(1)
    call DOSTOP('TNSMKS FOR_K_FP_QNAN')
    CASE(2)
    call DOSTOP('TNSMKS FOR_K_FP_POS_INF')
    CASE(3)
    call DOSTOP('TNSMKS FOR_K_FP_NEG_INF')
    CASE(4)
	! OK - FOR_K_FP_POS_NORM
    CASE(5)
	! OK - FOR_K_FP_NEG_NORM
	CASE(6)
    write(*,*) 'TNSMKS FOR_K_FP_POS_DENORM'
    CASE(7)
    write(*,*) 'TNSMKS FOR_K_FP_NEG_DENORM'
    CASE(8)
	! OK - FOR_K_FP_POS_ZERO
    CASE(9)
	! OK - FOR_K_FP_NEG_ZERO        ? Saw this with    0. * 9.900990099009901E-003
	!                               ? could have been -0. * 9.900990099009901E-003
    CASE DEFAULT
    call DOSTOP('TNSMKS FOR_K_FP_unknown')
  END SELECT
I have null/empty case blocks for 4, 5, 8, and 9.
These are cases I wish to ignore. However, case(8) in the observed case, falls through into case default.
Note, if I place something innocuous in the null cases, the select case behaves properly.
  SELECT CASE (J)
    CASE (0)
    CASE(1)
    CASE(2)
    CASE(3)
    CASE(4)
        J = 0
    CASE(5)
        J = 0
	CASE(6)
    CASE(7)
    CASE(8)
        J = 0
    CASE(9)
        J = 0
    CASE DEFAULT
  END SELECT
Intel® Fortran Compiler – toolkit version: 2023.0.0, extension version 23.0.0070.16, Package ID: w_oneAPI_2023.0.0.25839
Jim Dempsey
FortranFan
Jim,
You know the drill, Intel support team will want a reproducer but your original post does not provide one:
module m
contains
   subroutine sub( J )
      integer, intent(in) :: J
      SELECT CASE (J)
         CASE (0)
         CASE(1)
         CASE(2)
         CASE(3)
         CASE(4)
         CASE(5)
         CASE(6)
         CASE(7)
         CASE(8)
         CASE(9)
         CASE DEFAULT
      END SELECT
   end subroutine
   subroutine DOSTOP( s )
      character(len=*), intent(in) :: s
      print *, s
   end subroutine
end module
   use m
   call sub( 8 )
end
C:\temp>ifort /standard-semantics p.f90
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.8.0 Build 20221119_000000
Copyright (C) 1985-2022 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.34.31937.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
p.obj
C:\temp>p.exe
C:\temp>
Steve_Lionel
I can't reproduce the behavior you described. I tried this variant as a MRE:
   do j=0,9
   print *, j
  SELECT CASE (J)
    CASE (0)
    CASE(1)
    CASE(2)
    CASE(3)
    CASE(4)
    CASE(5)
	CASE(6)
    CASE(7)
    CASE(8)
    CASE(9)
    CASE DEFAULT
  END SELECT
end do
end
subroutine dostop (s)
character(*) :: s
print *, s
end subroutine dostop
When I built and ran this I got:
D:\Projects>ifort t.f90
-out:t.exe
-subsystem:console
t.obj
D:\Projects>t.exe
           0
           1
           2
           3
           4
           5
           6
           7
           8
           9
At first I thought that the syntax rule in the standard was wrong for a case construct in that it did not show the block as optional. But the syntax term for block itself allows it to be empty.
jimdempseyatthecove
Steve, maybe it is an ifort version issue. Yours is 2021.8.0 mine is 2023.0.0
Jim Dempsey
Steve_Lionel
There is no ifort version 2023.0.0. 2021.8.0 is the ifort in the current 2023.0.0 oneAPI release. ifx 2023.0.0 has the same correct behavior.
Show me a command line session building and running the complete program I posted above. Or, show me a complete program that demonstrates the behavior including build and run output.
jimdempseyatthecove
On my first post, at bottom, I listed the compiler identifier as displayed in the cmd window:
Yours shows:
Hmmm......
The output I listed above for me came from  MS VS 2019 Help | About.
When I issue ifort /help I get
The versioning that MS VS is reporting does not report the same as the command line (for the same compiler).
I can't account for why the posted code behaves differently on your system...
But wait, there's more...
In my build, I use fpp. In the code I posted was post fpp. The actual code segment has:
#ifdef _DEBUG
    J = FP_CLASS(ELBD)
  SELECT CASE (J)
    CASE (0)
    CASE(1)
    CASE(2)
    CASE(3)
    CASE(4)
    CASE(5)
	CASE(6)
#if 0
    call DOSTOP('TNSMKS FOR_K_FP_POS_DENORM')
#else
#endif
    CASE(7)
#if 0
    call DOSTOP('TNSMKS FOR_K_FP_NEG_DENORM')
#else
#endif
    CASE(8)
    CASE(9)
    CASE DEFAULT
  END SELECT
#endif
Jim Dempsey
Steve_Lionel
What you see in Visual Studio is the integration version, not the compiler version.
I have an idea I want to try out - stay tuned.
andrew_4619
Jim, the IDE versioning is very confusing, I have noted this before. If you build  in VS you see the correct Fortran version in the output window a la "Compiling with Intel® Fortran Compiler Classic 2021.7.0 [Intel(R) 64]..." in my case.
Also "Tools>Options> Intel Compilers....>IFORT.....>Compilers" gives all the versions and package versions etc.
Steve_Lionel
Idea didn't pan out. I'll repeat my request to provide a complete example that demonstrates the problem, including all commands used to build it. Or you could try the program I posted.
My best guess is that you're misinterpreting the behavior.
jimdempseyatthecove
How?
CASE(J), with J==8, fell through to CASE DEFAULT  with the result of making the CALL to DOSTOP
What happens for you if you initialize J via
var = 0.0
J = FP_CLASS(var)
replace call DOSTOP('...') with STOP '...'
Jim
Steve_Lionel
I'm not going to discuss this further without a full example, build command and output.
Steve_Lionel
@jimdempseyatthecove do you have a full test case yet? Or have you found the problem elsewhere?
JohnNichols
Honored Contributor I
Seems to work both ways.
!  Console3.f90
    !  FUNCTIONS:
    !  Console3 - Entry point of console application.
    !  PROGRAM: Console3
    !  PURPOSE:  Entry point for the console application.
    module m
    implicit none
   real, parameter :: pi = 3.1415926536
   real, parameter :: e = 2.7182818285
    contains
   subroutine show_consts()
      print*, "Pi = ", pi
      print*,  "e = ", e
   end subroutine show_consts
    subroutine sub( J )
    implicit none
    SELECT CASE (J)
    CASE (0)
    CASE(1)
    CASE(2)
    CASE(3)
    CASE(4)
    CASE(5)
    CASE(6)
    CASE(7)
    CASE(8)
    CASE(9)
        CASE DEFAULT
        call DOSTOP('TNSMKS FOR_K_FP_unknown  AA')
    END SELECT
    end subroutine
    implicit none
    print *, s
    end subroutine
    end module
    program Console3
    use m
    implicit none
    integer j
    j = 0
    call show_consts()
    do 100 j = 1,15
    print *, j
    call sub( j )
100 end do
    end program Console3
jimdempseyatthecove
Ok, I can't account for the observation I had. Thanks all for the time you've spent on this.
Jim Dempsey
JohnNichols
Jim:
Over many years, you have provided answers to a lot of my questions, a lot more time than I took to look at this interesting little problem.
It is just part of being a friend and I enjoy our friendship, so thank you
John
