29375 Discussions
Issue with optional assumed-rank arrays
PierU
This program below with a cascaded optional array, which is assumed-rank in the last called routine, works fine with gfortran, but fails on execution with any version of ifort/ifx.
module foo
implicit none
contains
   subroutine foo1(a)
      real, intent(in), optional :: a(:)
      call foo2(a)
   end subroutine
   subroutine foo2(a)
      real, intent(in), optional :: a(..)
      if (present(a)) then
         print*, rank(a)
      else
         print*, "a not present"
      end if
   end subroutine
end module
program bar
use foo
implicit none
   call foo1()
end
Is it a ifort/ifx bug, or is the code invalid?
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
libc.so.6 00007F889BE42520 Unknown Unknown Unknown
output.s 0000000000405214 Unknown Unknown Unknown
output.s 0000000000405450 Unknown Unknown Unknown
output.s 000000000040518D Unknown Unknown Unknown
libc.so.6 00007F889BE29D90 Unknown Unknown Unknown
libc.so.6 00007F889BE29E40 __libc_start_main Unknown Unknown
output.s 00000000004050A5 Unknown Unknown Unknown
Try it here: https://godbolt.org/z/8svecrEGc
Ron_Green
As you state, this segfaults with the current ifx 2024.0.0.  But I tested with our internal code that will come with our next update release, 2024.1.0.  In this future version of 2024.1.0 it is fixed in ifx and ifort
$ ifx repro.f90
$ ./a.out
a not present
Ron_Green
$ ifx repro.f90
$ ./a.out
a not present
riad_h_1
I  have a similar issue even with  the 2024.1 release:
integer, allocatable :: x
print*,'When x is unallocated:'
call foo(x); call foo_ar(x)
print*,'When x is allocated:'
x = 1
contains
   subroutine foo ( x )
      integer, optional, intent(in) :: x
      if ( present(x) ) then
         print*,'- with foo: x is present'
      else
         print*,'- with foo: x is absent'
      end if
   end subroutine foo
   subroutine foo_ar ( x )
      integer, optional, intent(in) :: x(..)
         print*,'- with foo_ar: x is present'
      else
         print*,'- with foo_ar: x is absent'
      end if
   end subroutine foo_ar
end
I get with ifx ((IFX) 2024.1.2 20240508):
While with gfortran (GNU Fortran (SUSE Linux) 7.5.0):
Ron_Green
A new and different bug.  I will open a new bug report. Thank you for finding this.
15.5.2.13 Argument presence and restrictions on arguments not present
   A dummy argument or an entity that is host associated with a dummy  argument is not present if the dummy argument
  • does not correspond to an actual argument
  • corresponds to an actual argument that is not present, or
  • does not have the ALLOCATABLE or POINTER attribute, and corresponds to an actual argument that
    • has the ALLOCATABLE attribute and is not allocated, or
    • has the POINTER attribute and is disassociated;
otherwise, it is present.
Ron_Green
bug tracking ID is CMPLRLLVM-59233
Devorah_H_Intel
The second reported issue is fixed in 2025.0 ifx.
