29487 Discussions
Issues discovered when overloading "generic :: operator(-)"
Alberto_F__M_
Dear Intel Fortran Compiler for Linux and Mac OS X users and developers,
I think that I found a number of issues when overloading "generic :: operator(-)" on a base derived data type -- let's call it A -- and calling the corresponding bindings with instances of a derived data type which extends A, --let's call it B--. The different scenarios tested were gathered in five programs attached to this post: test1.f90, test2.f90, test3.f90, test4.f90, and test5.f90. The outcome was as follows:
- test1.f90 compiles and generates the output that I would expect (OK).
amartin@Aetos:~/pruebas_fortran_03$ ifort test1.f90
amartin@Aetos:~/pruebas_fortran_03$ ./a.out
   2.000000
   2.000000
- test2.f90 compiles but it DOES NOT provide the output that I would expect (I believe the expected output should be the same as the one provided by test1.f90) (NO-OK).
amartin@Aetos:~/pruebas_fortran_03$ ifort test2.f90
   2.000000
- test3.f90 compiles but and generates the output that I would expect (OK).
amartin@Aetos:~/pruebas_fortran_03$ ifort test3.f90
   1.000000
- test4.f90 DOES NOT compile, and I believe that it should compile (NO-OK).
amartin@Aetos:~/pruebas_fortran_03$ ifort test4.f90
test4.f90(46): error #6355: This binary operation is invalid for this data type.   [B_INSTANCE]
  write(*,*) B_instance-B_instance
test4.f90(46): error #6549: An arithmetic or LOGICAL type is required in this context.
compilation aborted for test4.f90 (code 1)
- test5.f90 compiles and generates the output that I would expect (OK).
amartin@Aetos:~/pruebas_fortran_03$ ifort test5.f90
   1.000000
   1.000000
If you take a careful look at the code snippets, you may observe that the NO-OK tests are the ones where the "generic :: operator(-)" is overloaded for both the unary and binary minus operator.
Could you please help me and determine whether the codes are standard compliant, and confirm that they should provide the outputs that I except? In case I am correct, is there any compiler-related issue? Can it be work-arounded? Should it be fixed?
I got the same behaviour with both the 15.0.2 and 16.0.0 compiler versions.With the GNU gfortran compiler (5.1.0) all tests compiled and generated the output that I would expect.
Many thanks in advance for your help.
FortranFan
.. Could you please help me and determine whether the codes are standard compliant, and confirm that they should provide the outputs that I except? In case I am correct, is there any compiler-related issue? Can it be work-arounded? Should it be fixed?
Your code appears standard-conforming and the underlying issue seems to be in Intel Fortran which, if accepted by the Intel team as such, should get fixed.
You ask, "Can it be work-arounded?"  How about going with a lettered defined operation until the compiler gets fixed?
module A_class
   implicit none
   type :: A
   contains
      procedure :: minus_A
      procedure :: sub_A
      generic :: operator(-) => minus_A
      generic :: operator(.minus.) => sub_A
   end type A
contains
   function sub_A(op1,op2) result(res)
      implicit none
      class(A), intent(in) :: op1, op2
      real :: res
      res=1.0
   end function sub_A
   function minus_A(op) result(res)
      implicit none
      real :: res
      res=2.0
   end function minus_A
end module A_class
module B_class
   use A_class, only : A
   implicit none
   type, extends(A) :: B
   end type B
end module B_class
program example_program
   use B_class, only : B
   implicit none
   type(B), target :: B_instance
   class(A), pointer :: A_pointer
   A_pointer => B_instance
   write(*,*) -B_instance
   write(*,*) -A_pointer
   stop
end program example_program
 2.000000
 2.000000
Press any key to continue . . .
Kevin_D_Intel
@Alberto, I will look into your test cases also and reply again after knowing more.
@FortranFan, Appreciate your investigating and for the work around.
