Issues with OUT_OF_RANGE
Harald1
New Contributor II
I found the following issues with ifx regarding this F2018 intrinsic:
program p
  use iso_fortran_env, only: int32, real32
  implicit none
  integer(int32) :: i4
  real(real32)   :: r4 = 1.e9
  logical        :: t = .true., f = .false.
  print *, OUT_OF_RANGE (r4, i4, round=f)
  print *, OUT_OF_RANGE (r4, i4, round=t)
  print *, OUT_OF_RANGE (r4, i4)          ! ROUND is optional here!
  ! Check passing of optional argument
  print *, my_out_of_range (r4, round=f)
  print *, my_out_of_range (r4, round=t)
  print *, my_out_of_range (r4)           ! This crashes
contains
  elemental logical function my_out_of_range (x, round)
    real(real32), intent(in)           :: x
    logical,      intent(in), optional :: round
    my_out_of_range = out_of_range (x, 0_int32, round)
  end function my_out_of_range
end
 This runs correctly until line 15, where the missing optional argument is mishandled when transferring the optional dummy to the optional argument of the intrinsic.  Since for other Fortran intrinsics optional arguments are properly dealt with by the compiler, it fails here for no good reason.
% ifx ifx-out_of_range.f90 -g -traceback && ./a.out
ifx: remark #10440: Note that use of a debug option without any optimization-level option will turnoff most compiler optimizations similar to use of '-O0'
 F
 F
 F
 F
 F
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
libc.so.6          00007FF408257980  Unknown               Unknown  Unknown
a.out              0000000000405898  my_out_of_range            19  ifx-out_of_range.f90
a.out              0000000000405818  p                          15  ifx-out_of_range.f90
a.out              00000000004055AD  Unknown               Unknown  Unknown
libc.so.6          00007FF408240EEC  Unknown               Unknown  Unknown
libc.so.6          00007FF408240FB5  __libc_start_main     Unknown  Unknown
a.out              00000000004054B1  Unknown               Unknown  Unknown
Furthermore, the following example is rejected:
program p
  logical, parameter :: l0 = OUT_OF_RANGE (1.e9, 0)
end
 I get:
% ifx ifx-out_of_range2.f90
ifx-out_of_range2.f90(2): error #6263: This intrinsic function is invalid in constant expressions.   [OUT_OF_RANGE]
compilation aborted for ifx-out_of_range2.f90 (code 1)
 NAG compiles this one just fine, and I cannot find anything in the F2023 standard that confirms what ifx claims.
Harald
Steve_Lionel
This is the ongoing issue of Intel Fortran not allowing "specification inquiry" functions (F2018 10.1.11p3, 10.1.12p1(4)) in constant expressions. It's been 2-3 years at least since I first brought this up to the team.
