I loaded Fortran XE Proupdate 3. Then I rebuild my solution as usual under Win32, it went through fine and I could execute the programs as usual.
Then I tried to switch to x64 by going through Tools Options Intel Visual Fortran Compilers and I changed the platform from Win32 to x64. When I rebuild the solution, the compiler replied right away succeeded, but in fact it did not do anything.
Since then, I have not been able to rebuild the solution, I tried to use Win32, to reload a back up copy of my solution, to delete the intermediate files, to delete the executable files, nothing worked.
When I build any of the projects or the entire solution the answer is up-to-date and when I re-build them the answer is deleting intermediate files and succeeded, but nothing is done !
I dont know if it has to see with update 3, with x64, or anything else., but I need to work and I am stuck. Any idea ?
It did correct the problem.
Many thanksfor your quick and helpfull answer, as well as for maintaining the forum which do help me a lot.
