I installed the latest fortran Intel Visual Fortran Composer XE 2011 Integration for Microsoft Visual Studio* 2008, 12.0.3470.2008, Copyright (C) 2002-2010 Intel Corporationworkstation software, found no IMSL library, add the path the way through but failed to increase, how to add imsl Library
The IMSL library compatible with Intel Visual Fortran Composer XE 2011 has not yet been released.
> ..add the path the way through but failed to increase,..
That is incomprehensible. Please restate.
IMSL is not included in the downloads for the compiler. Did you obtain the IMSL installer from Intel or VNI? If so, which version, and is it known to be compatible with IFort XE 2011 ?
