Iterative Sparse Solvers based on Reverse Communication Interface (RCI ISS)
Hoang__Dat
Dear Sir/Madam,
I am grateful for the development of Intel Visual Fortran Compiler for Windows. It helps my work a lot.
I would like to ask about RCI ISS in the newest Intel MKL solver. I know that in Intel MKL, there is an RCI conjugate gradient solver.
Hence, does it work well with EBE-PCG (element by element preconditioner conjugate gradient) method or can I build my code for EBE-PCG method using Intel MKL solver?
Thank you very much!
Tien-Dat
Steve_Lionel
I suggest you post this in the MKL forum.
Hoang__Dat
Thank you very much.  I will follow your suggestion.
