29648 Discussions
Jumping from a CASE statement cascade to a program block down below (F90)
TommyCee
Consider this CASE statement cascade:
If (Title .eq. 'Some Character String ')THEN
Select Case(L)
CASE(1)
OPEN (11, FILE = 'File1.txt', STATUS = 'unknown')
GoTo 100
CASE(2)
OPEN (12, FILE = 'File2.txt', STATUS = 'unknown')
GoTo 100
CASE(3)
OPEN (13, FILE = 'File3.txt', STATUS = 'unknown')
GoTo 100
CASE(4)
OPEN (14, FILE = 'File4.txt', STATUS = 'unknown')
GoTo 100
CASE(5)
OPEN (15, FILE = 'File5.txt', STATUS = 'unknown')
GoTo 100
End Select
When the appropriate CASE is found, I want to jump below to a DO loop that startrs at line 100, e.g.,
100 DO 200, i = 1,n
{statements}
200 EndDo
On compile, I get this error message (it says "Warning" but believe me - it's a show-stopping ERROR):
Warning: A jump into a block from outside the block may have occurred. [100]
Is there no way to do this? Is this kind of "jumping" strictly verboten in F90?
Is there a slick work-around?
I earlier configured this as an if/then cascade and the "jumps" worked fine. Is there something unique about the CASE cascade?
Any help is appreciated.
TC
TommyCee
Oops! I'll answer my own question:
Yes, you CAN jump off from a CASE cascade. I presented an IF branch of the code that nests the CASE cascade (excerpt pasted above). At the bottom of a few more If/Then blocks, I accidentaly commented out my EndIf statement, so the IF/THEN block wasn't properly terminated. {Frankly, I'm surprised why the compiler didn't complain about that and directly point it out but it didn't.}
Anyway, I got my answer (the hard way, as usual).
I hack on ...
smile
Can you show a complete program with the missing endif that doesn't get an error?
mecej4
I reconstructed this example based on what I read in this thread. The Intel compiler seems willing to allow a jump into an IF construct with only a warning.
[fortran]subroutine tsub()
   character(len=50) :: Title
   Integer :: I,j
   j = 100
      Select Case(L)
         CASE(1)
            GoTo 100
         CASE(2)
            GoTo 100
      End Select
      j = 0
   End If
   if(j.eq.100)Then
      j=j+50
!   EndIf      ! This is the missing EndIf
100   DO i = 1,n
          j=i*i+j
       EndDo
    return
    EndIf      ! misplaced EndIf, incorrect fix for syntax error reported earlier
    Return
end subroutine tsub
[/fortran]
TommyCee
In reply to Steve's request, I'm sorry to say that I vastly re-coded that program and so the original structure is lost. Sorry. But trust me, the error messaging was as I described. Sounds like you were more surpised than I was.
TommyCee
Actually, now that I pay better attention, MECEJ4 did a pretty good job in reconstructing what I presented. Except that when my program bailed out of one of the CASEs (GoTo100), 100 was not in an If/Then construct; it was just part of a series of program code. Not sure if that changes his interpretation but I just wanted to set it straight.
I revise MECEJ4's code as follows (this is a little more like what I had):
  1. program OffMyCase
  2. character(len=50)::Title
  3. Integer::I, j , L
  4. If(Title.eq.'SomeCharacterString')THEN
  5. SelectCase(L)
  6. CASE(1)
  7. OPEN(11,FILE='File1.txt',STATUS='unknown')
  8. GoTo100
  9. CASE(2)
  10. OPEN(12,FILE='File2.txt',STATUS='unknown')
  11. GoTo100
  12. EndSelect
  13. EndIf <== THIS was the missing EndIf
  14. 100DOi=1,n
  15. j=i*i+j
  16. EndDo
  17. end program OffMyCase
mecej4
No, this version of the source, with the EndIf commented out, results in an error:
[bash]jmp.f90(5): error #6321: An unterminated block exists.
compilation aborted for jmp.f90 (code 1)
[/bash]
In this code, there is no reason for the compiler to issue the warning "A jump into a block from outside the block may have occurred".
I think that the compiler will not let code with an IF block without an EndIF go with just a warning.
I have never seen a case where the compiler failed to diagnose a missing END IF.
In the tests I have constructed, a jump into a block gets a warning, not an error. Such jumps have always been illegal in Fortran (*), and even though the compiler does not give an error, the results of such a jump can be unpredictable. I remember coding the logic in the VAX Fortran compiler to detect such jumps.
(*) An exception is the Fortran 66 "Extended range of a DO loop" feature, where you could jump out of a DO loop and back into the samel level. This was removed in Fortran 77. Intel Fortran still allows this, again with a warning.
TommyCee
I went back and re-created that which I had discarded in the evolution of my program. I totally duplicated the problem I originally reported on this thread. I stand corrected and what I will say now validates what Steve & others have said: the Intel compiler will always diagnose (and flag as an error) a missing EndIf.
When my condition initially happened, the compiler (in the Build View area at the bottom of the IDE) listed a series of warnings pointing to the statement labels associated with the GoTo's in the CASE cascade. This was as I posted initially. What I failed to notice, listed way below, was the ever-familiar:
Error: An unterminated block exists.
I didn't see it! One question I do have (of the compiler) is:
Why not list the show-stopping errors FIRST?
It turns out that the warnings were just vague "contingencies" that, once the If/Then was properly terminated, went away.
Thanks for the attention to this and sorry for any confusion this post caused, but it was instructive (for me anyhow).
TC
TimP
I'm not a good example about habit-forming, but one of my habits for failed computation is to run "grep Error" on the build log. I wouldn't be capable of running even under Windows without installing grep. If you have a bias against that, there's always the ctrl-F search method for Windows text viewers.
The missing ENDIF wasn't detected until the end of the program unit - errors come out in the order they are detected.
TommyCee
10-4, Steve. I guess you make a good point that validates the behavior seen (re: warning/error flagging sequence). Good call.
