Kmeans++
JohnNichols
Honored Contributor I
I have been playing with KMEANS for a while, but I wanted to try it in Fortran.
Anyway, here is a F90 version of the f77 version on the web.  Rosettacode.org.
    ! KMPP - K-Means++ - Traditional data clustering with a special initialization
    ! Public Domain - This program may be used by any person for any purpose.
    ! Origin:
    !    Hugo Steinhaus, 1956
    ! Refer to:
    !    "kmeans++: the advantages of careful seeding"
    !    David Arthur and Sergei Vassilvitskii
    !    Proceedings of the eighteenth annual ACM-SIAM symposium
    !      on Discrete algorithms, 2007
    !____Variable_______I/O_______Description___________________Type_______
    !    X(P,N)         In        Data points                   Real
    !    P              In        Dimension of the data         Integer
    !    N              In        Number of points              Integer
    !    K              In        # clusters                    Integer
    !    C(P,K)         Out       Center points of clusters     Real
    !    Z(N)           Out       What cluster a point is in    Integer
    !    WORK(N)        Neither                                 Real
    !    IFAULT         Out       Error code                    Integer
    SUBROUTINE KMPP (X, P, N, K, C, Z, WORK, IFAULT)
    IMPLICIT NONE
    INTEGER P, N, K, Z, IFAULT
    REAL X, C, WORK
    DIMENSION X(P,N), C(P,K), Z(N), WORK(N)
    !               constants
    INTEGER ITER                 ! maximum iterations
    REAL BIG                     ! arbitrary large number
    PARAMETER (ITER = 1000, BIG = 1E33)
    !                local variables
    INTEGER    H          ! count iterations
    INTEGER         I          ! count points
    INTEGER          I1         ! point marked as initial center
    INTEGER         J         ! count dimensions
    INTEGER         L          ! count clusters
    INTEGER         L0         ! present cluster ID
    INTEGER         L1          ! new cluster ID
    REAL  BEST                 ! shortest distance to a center
    REAL      D2                   ! squared distance
    REAL      TOT                  ! a total
    REAL      W                     ! temp scalar
    LOGICAL CHANGE             ! whether any points have been reassigned
    !           Begin.
    IFAULT = 0
    IF (K < 1 .OR. K > N) THEN       ! K out of bounds
        IFAULT = 3
        RETURN
    END IF
    DO I = 1, N                       ! clear Z
        Z(I) = 0
    END DO
    !        initial centers
    DO I = 1, N
        WORK(I) = BIG
    END DO
    CALL RANDOM_NUMBER (W)
    I1 = MIN(INT(W * FLOAT(N)) + 1, N)  ! choose first center at random
    DO J = 1, P
        C(J,1) = X(J,I1)
    END DO
    DO L = 2, K                    ! initialize other centers
        TOT = 0.
        DO I = 1, N                     ! measure from each point
            BEST = WORK(I)
            D2 = 0.                         ! to prior center
            DO J = 1, P
                D2 = D2 + (X(J,I) - C(J,L-1)) **2  ! Squared Euclidean distance
                IF (D2 .GE. BEST) GO TO 10               ! needless to add to D2
            END DO                          ! next J
            IF (D2 < BEST) BEST = D2          ! shortest squared distance
            WORK(I) = BEST
10          TOT = TOT + BEST             ! cumulative squared distance
        END DO                      ! next data point
        ! Choose center with probability proportional to its squared distance
        !     from existing centers.
        W = W * TOT    ! uniform at random over cumulative distance
        TOT = 0.
        DO I = 1, N
            I1 = I
            TOT = TOT + WORK(I)
            IF (TOT > W) GO TO 20
        END DO                ! next I
20      CONTINUE
        DO J = 1, P         ! assign center
            C(J,L) = X(J,I1)
        END DO
    END DO               ! next center to initialize
    !                      main loop
    DO H = 1, ITER
        CHANGE = .FALSE.
        !             find nearest center for each point
        DO I = 1, N
            L0 = Z(I)
            L1 = 0
            BEST = BIG
            DO L = 1, K
                D2 = 0.
                DO J = 1, P
                    D2 = D2 + (X(J,I) - C(J,L)) **2
                    IF (D2 .GE. BEST) GO TO 30
                END DO
30              CONTINUE
                IF (D2 < BEST) THEN           ! new nearest center
                    BEST = D2
                    L1 = L
                END IF
            END DO        ! next L
            IF (L0 .NE. L1) THEN
                Z(I) = L1                   !  reassign point
                CHANGE = .TRUE.
            END IF
        END DO         ! next I
        IF (.NOT. CHANGE) RETURN      ! success
        !           find cluster centers
        DO L = 1, K              ! zero population
            WORK(L) = 0.
        END DO
        DO L = 1, K               ! zero centers
            DO J = 1, P
                C(J,L) = 0.
            END DO
        END DO
        DO I = 1, N
            L = Z(I)
            WORK(L) = WORK(L) + 1.             ! count
            DO J = 1, P
                C(J,L) = C(J,L) + X(J,I)         ! add
            END DO
        END DO
        DO L = 1, K
            IF (WORK(L) < 0.5) THEN          ! empty cluster check
                IFAULT = 1                     ! fatal error
                RETURN
            END IF
            W = 1. / WORK(L)
            DO J = 1, P
                C(J,L) = C(J,L) * W     ! multiplication is faster than division
            END DO
        END DO
    END DO                   ! next H
    IFAULT = 2                ! too many iterations
    RETURN
    END  ! of KMPP
    !             test program (extra credit #1)
    PROGRAM TPEC1
    IMPLICIT NONE
    Integer, PARAMETER :: N = 30, P = 2, K = 6
    REal, Parameter :: TWOPI = 6.2831853
    INTEGER I, L, Z(N), IFAULT
    REAL X(P,N), C(P,K), R, THETA, W, WORK(N)
    !             Begin
    CALL RANDOM_SEED()
    DO I = 1, N                      ! random points over unit circle
        R = SQRT(W)                      ! radius
        THETA = W * TWOPI                ! angle
        write(*,*)"A   :: ",I, R,THETA
        X(1,I) = R * COS(THETA)          ! Cartesian coordinates
        X(2,I) = R * SIN(THETA)
        !write(*,*)I,X(1,I),X(2,I)
    END DO
    !             Call subroutine
    CALL KMPP (X, P, N, K, C, Z, WORK, IFAULT)
    PRINT *, 'kmpp returns with error code ', IFAULT
    !            Print lists of points in each cluster
    DO L = 1, K
        PRINT *, 'Cluster ', L, ' contains points: '
10      FORMAT (I6, $)
20      FORMAT ()
        DO I = 1, N
            IF (Z(I) .EQ. L) PRINT 10, I
        END DO
        PRINT 20
    END DO
    !         Write CSV file with Y-coordinates in different columns by cluster
    OPEN (UNIT=1, FILE='tpec1.csv', STATUS='UNKNOWN', IOSTAT=IFAULT)
    IF (IFAULT .NE. 0) PRINT *, 'tpec1: trouble opening file'
30  FORMAT (F8.4, $)
40  FORMAT (',', $)
50  FORMAT (F8.4)
    DO I = 1, N
        WRITE (UNIT=1, FMT=30, IOSTAT=IFAULT) X(1,I)
        IF (IFAULT .NE. 0) PRINT *, 'tpec1: trouble writing X-coord'
        DO L = 1, Z(I)                     ! one comma per cluster ID
            WRITE (UNIT=1, FMT=40, IOSTAT=IFAULT)
            IF (IFAULT .NE. 0) PRINT *, 'tpec1: trouble writing comma'
        END DO
        WRITE (UNIT=1, FMT=50, IOSTAT=IFAULT) X(2,I)
        IF (IFAULT .NE. 0) PRINT *, 'tpec1: trouble writing Y-coord'
    END DO
    !           Write the centroids in the far column
    DO L = 1, K
        WRITE (UNIT=1, FMT=30, IOSTAT=IFAULT) C(1,L)
        DO I = 1, K+1
        END DO
        WRITE (UNIT=1, FMT=50, IOSTAT=IFAULT) C(2,L)
    END DO
    CLOSE (UNIT=1)
    END  ! of test program
it needs more work, but it is a neat little program.
JohnNichols
n = RGBnode%nn
    call RGBnode%fill(1,n )
I have to declare an integer n(2) and set it to pass n RGBnode%nn into the subroutine, it will not pass directly - I just do not understand why I need to do this?
Line 194 is the relevant subroutine.
 module rgbimage_m
    implicit none
    private
    public :: rgbimage
    INTEGER, PARAMETER :: dp = selected_real_kind(15, 307)
    REAL (KIND=dp) :: g = 9.806, pi = 3.14159265D0
    type rgbimage
        !! usage
        !!    1) init
        !!    2a) fill_image
        !!      or
        !!    2b) set_pixel
        !!    3) normalize
        !!    4) write
        integer Colred(3), colgre(3), colblu(3), Colyel(3)
        integer, dimension(:,:,:), allocatable :: input
        integer, dimension(:,:,:), allocatable :: rgb
        !! pixel arrays of rgb values
        !! indices (i,j,k)
        !!    i: position x_i
        !!    j: position y_j
        !!    k=1: red, k=2: green, k=3: blue
        integer :: n(2)
        !! image dimensions: [height, width]
        integer :: nn(2)
        !! image input dimensions: [height, width]
    contains
    procedure :: init       => rgbimage_init              ! inits image
    procedure :: fill_image => rgbimage_fill_image        ! fill image with constant rgb value
    procedure :: get_pixel  => rgbimage_get_pixel         ! gets one pixel
    procedure :: normalize  => rgbimage_normalize         ! normalizes all pixels onto range [0, 255]
    procedure :: set_pixel  => rgbimage_set_pixel         ! sets one pixel
    procedure :: write      => rgbimage_write             ! outputs image to file
    procedure :: fill      => rgbimage_fill               ! outputs image to file
    procedure, private :: inside => rgbimage_inside
    procedure, private :: valid  => rgbimage_valid
    end type
    contains
    subroutine rgbimage_init(this, height, width)
    !! initialize image.
    !! sets dimensions, allocates pixels and sets colors to 0.
    class(rgbimage), intent(out) :: this
    integer,         intent(in)  :: height, width
    integer astat
     integer, parameter :: ihpixf =  4096, jvpixf = 4096 ! pixel size, jvpixf
    this%n = [height, width]
    this%nn = [ihpixf,jvpixf]
    allocate (this%rgb(height,width,3), source=0, STAT = astat)
    if(astat == 0) then
        write(*,*)"Allocated matrix"
    else
        stop "Failed to allocate matrix"
    end if
    allocate(this%input(3,ihpixf,jvpixf),STAT = astat)
    if(astat == 0) then
    else
    end if
    this%Colgre(1) = 248
    this%Colgre(2) = 248
    this%Colgre(3) = 255
    this%Colyel(1) = 248
    this%Colyel(2) = 100
    this%Colyel(3) = 100
    this%Colblu(1) = 50
    this%Colblu(2) = 56
    this%Colblu(3) = 200
    this%Colred(1) = 200
    this%Colred(2) = 256
    this%Colred(3) = 256
    return
    end subroutine
    logical function rgbimage_valid(this, check_rgb_vals)
    !! checks if the image has valid dimensions and optionally valid rgb values.
    class(rgbimage), intent(in)           :: this
    logical,         intent(in), optional :: check_rgb_vals
    !! check if rgb values are in allowed range [0, 255]?
    !! default: dont check
    ! always check that dimensions match
    rgbimage_valid = ( all(this%n > 0)                     .and. &
        &               (size(this%rgb, dim=1) == this%n(1)) .and. &
        &               (size(this%rgb, dim=2) == this%n(2)) .and. &
        &               (size(this%rgb, dim=3) == 3)               )
    ! optionally: check if rgb values are in allowed range
    if (present(check_rgb_vals)) then
        if (check_rgb_vals) rgbimage_valid = ( rgbimage_valid       .and. &
            &                                   (all(this%rgb >= 0))  .and. &
            &                                   (all(this%rgb <= 255))      )
    end if
    end function
    logical function rgbimage_inside(this, x, y)
    !! checks if given coordinates are inside the image
    integer,         intent(in) :: x, y
    rgbimage_inside = ((x > 0) .and. (x <= this%n(1)) .and. (y > 0) .and. (y <= this%n(2)))
    end function
    subroutine rgbimage_set_pixel(this, x, y, rgb)
    class(rgbimage), intent(inout) :: this
    !! coordinates
    integer,         intent(in)    :: rgb(3)
    !! red, green, blue values
    if (this%inside(x, y)) then
        ! use given data at first
        this%rgb(x,y,:) = rgb
        ! check if given data was out of bounds
        where     (this%rgb(x,y,:) > 255)
            this%rgb(x,y,:) = 255
        elsewhere (this%rgb(x,y,:) < 0)
            this%rgb(x,y,:) = 0
        end where
    end if
    end subroutine
    function rgbimage_get_pixel(this, x, y) result(rgb)
    !! coordinates
    integer                     :: rgb(3)
        rgb = this%rgb(x,y,:)
    else
        rgb = 0
    end if
    end function
    subroutine rgbimage_normalize(this)
    !! normalize colors to be in range [0, 255]
    where     (this%rgb(:,:,:) > 255)
        this%rgb(:,:,:) = 255
    elsewhere (this%rgb(:,:,:) < 0)
        this%rgb(:,:,:) = 0
    end where
    end subroutine
    subroutine rgbimage_fill_image(this, rgb)
    !! fill whole image with given rgb values.
    integer :: i
    if (this%valid()) then
        do i = 1, 3
            this%rgb(:,:,i) = rgb(i)
        end do
    end if
    end subroutine
    subroutine rgbimage_fill(this, i, n)
    implicit none
    integer, intent(in) :: i, n(2)
    integer j
    do 100 j = 1, n(1)
    write(*,*)"Here  :: ",i,j
100 end do
    return
    end subroutine
    subroutine rgbimage_write(this, fname)
    character(*),    intent(in) :: fname
    character*100 :: error
    !! file path, e.g. "tmp/out.ppm"
    integer :: iounit, ios, i,j,k
    open (newunit=iounit, file=fname, iostat=ios, action='WRITE')
    if (ios /= 0) then
        write(error,100)fname
100     format(    "Error opening file: ", A20)
        stop 'Error opening file'
    endif
    ! write header
    write (iounit, '(A)')         'P6'
    write (iounit, '(I0, A, I0)') this%n(1), " ", this%n(2)
    write (iounit, '(A)')         '255'
    do i = 1, this%n(1)
        do j = 1, this%n(2)
            write (iounit, '(3A1)', advance='no') [(achar(this%rgb(i,j,k)), k=1,3)]
        end do
    end do
    close (unit=iounit, iostat=ios)
    if (ios /= 0) error stop "Error closing file"
    end subroutine
    ! Notes
    ! o With a parameter ipixout set at 1, 2 or others,
    !   this subroutine will generate PPM-P6(binary), PPM-P3(text),
    !   or BMP(24bit depth without color table).
    ! o Some parts follow DEC-FORTRAN convention that had been defacto-standard long ago.
    !   Some compilers today may not accept if "ipixout" is set other than 2.
    ! o g77 (ver. 3.3.3) works for all three choices.
    ! o Intel compiler (ver. 9 or later) works for all three choices.
    subroutine pixout(rgb,nframe)
    implicit none
    ! interface arg.
    integer ihpixf, jvpixf
    parameter(ihpixf = 4096, jvpixf = 4096) ! pixel size, eacg must be multiple of 4, if BMP is chosen as output format.
    character*1 rgb(3,ihpixf,jvpixf)      ! RGB data array
    integer nframe
    ! local
    character*12 fnameout
    integer i, j, k
    integer itmp, icnt
    character*14 frmtstr
    character*54 headmsw
    character*4  byt4
    character*2  byt2
    ! choices
    integer ipixout
    parameter(ipixout = 3) ! 1 / 2 / other= PPM6, PPM3, BMP(24bit)
    if (ipixout .EQ. 1) then
        ! PPM P6
        write(fnameout,'(''smpl'',i3.3,''.ppm'')') nframe ! name of PPM file
        open(unit=2,file=fnameout,status='unknown')
        write(*,*) 'Now writing PPM (P6) file : ', fnameout
        ! header
        write(2,'(''P6'', 2(1x,i4),'' 255 '',$)')ihpixf, jvpixf
        ! image data
        itmp = ihpixf ! jvpixf ! 3
        write(frmtstr,'(''('',i8.8,''A,$)'')') itmp     ! make output "format"
        write(2,fmt=frmtstr) (((rgb(k,i,j),k=1,3),i=1,ihpixf),j=jvpixf,1,-1)
        close(2)
    else if (ipixout .EQ. 2) then
        ! PPM P3 ! rather "safer" choice for many Fortran compiler(s).
        write(*,*) 'Now writing PPM (P3) file : ', fnameout
        ! header
        write(2,'(A)') 'P3'
        write(2,'(2(1x,i4),'' 255 '')')  ihpixf, jvpixf
        icnt = 0
        ! image data
        do j = jvpixf, 1, -1                              ! here, j (vertical address) runs from top to bottom.
            do i = 1, ihpixf, 1
                do k = 1, 3
                    itmp = ichar(rgb(k,i,j))
                    icnt = icnt + 4
                    if (icnt .LT. 60) then
                        write(2,fmt='(1x,i3,$)') itmp                 ! "$" is not standard.
                    else
                        write(2,fmt='(1x,i3)') itmp
                        icnt = 0
                    endif
                enddo
            enddo
        enddo
        write(2,'(A)') ' '
        close(2)
    else
        ! BMP (24bit depth)... this part works only when width is multiple of 4.
        itmp = mod(ihpixf, 4)
        if (itmp .NE. 0) then
            write(*,*) 'width must be multiple of 4'
            stop
        endif
        write(fnameout,'(''smpl'',i3.3,''.bmp'')') nframe ! name of BMP file
        write(*,*) 'Now writing BMP(24bit) file : ', fnameout
        ! header 1 (file header ; 1--14 byte)
        headmsw( 1: 2) = 'BM'             ! declaring this is BMP file
        itmp = 54 + ihpixf * jvpixf * 3 ! total file size = header + data
        call num2bit4(itmp,byt4)
        headmsw( 3: 6) = byt4(1:4)
        itmp = 0                        ! may be 0
        call num2bit2(itmp,byt2)
        headmsw( 7:  = byt2(1:2)
        itmp = 0                        ! may be 0
        headmsw( 9:10) = byt2(1:2)
        itmp = 54                       ! must be 54 : total length of header
        headmsw(11:14) = byt4(1:4)
        ! header 2 (bit-map header ; 13--54 byte)
        itmp = 40                       ! must be 40 : length of bit-map header
        headmsw(15:18) = byt4(1:4)
        itmp = ihpixf                   ! width
        headmsw(19:22) = byt4(1:4)
        itmp = jvpixf                   ! height
        headmsw(23:26) = byt4(1:4)
        itmp = 1                        ! must be 1
        headmsw(27:28) = byt2(1:2)
        itmp = 24                       ! must be 24 : color depth in bit.
        headmsw(29:30) = byt2(1:2)
        itmp = 0                        ! may be 0 : compression method index
        headmsw(31:34) = byt4(1:4)
        itmp = 0                        ! may be 0 : file size if compressed
        headmsw(35:38) = byt4(1:4)
        itmp = 0                        ! arbit. : pixel per meter, horizontal
        headmsw(39:42) = byt4(1:4)
        itmp = 0                        ! arbit. : pixel per meter, vertical
        headmsw(43:46) = byt4(1:4)
        itmp = 0                        ! may be 0 here : num. of color used
        headmsw(47:50) = byt4(1:4)
        itmp = 0                        ! may be 0 here : num. of important color
        headmsw(51:54) = byt4(1:4)
        ! writing header part
        write(2,'(a54,$)') headmsw(1:54)
        ! image data
        itmp = ihpixf * jvpixf * 3
        write(2,fmt=frmtstr) (((rgb(k,i,j),k=3,1,-1),i=1,ihpixf),j=1,jvpixf) ! writing in BGR order, not RGB.
        close(2)
    endif
    return
    end subroutine pixout
    ! convert integer values to 4 8-bit characters
    subroutine num2bit4(inum,byt4)
    implicit none
    integer inum
    character*4 byt4
    integer itmp1, itmp2
    itmp1 = inum
    itmp2 = itmp1 / 256**3
    byt4(4:4) = char(itmp2)
    itmp1 =-itmp2 * 256**3 +itmp1
    itmp2 = itmp1 / 256**2
    byt4(3:3) = char(itmp2)
    itmp1 =-itmp2 * 256**2 +itmp1
    itmp2 = itmp1 / 256
    byt4(2:2) = char(itmp2)
    itmp1 =-itmp2 * 256    +itmp1
    byt4(1:1) = char(itmp1)
    return
    end subroutine num2bit4
    ! convert integer values to 2 8-bit characters
    subroutine num2bit2(inum,byt2)
    implicit none
    integer inum
    character*2 byt2
    itmp1 = inum
    itmp2 = itmp1 / 256
    byt2(2:2) = char(itmp2)
    itmp1 =-itmp2 * 256 + itmp1
    byt2(1:1) = char(itmp1)
    return
    end subroutine num2bit2
    !   fill rgb data array with something
    ! Sample FORTRAN 77 program to make PPM / BMP
    !  1998-Apr-03 (long long ago)
    !  2005-Jul-22 (added P3)
    !  2006 Dec-22 (added BMP)
    !  Image array rgb(3,!,!) is filled in subroutine mkbitmap()
    !  and
    !  saved in PPM or BMP format in subroutine pixout().
    !                                   K. Hayashi
    subroutine pixelout(input, mag)
    implicit none
    character*1 rgb(3,ihpixf,jvpixf) ! RGB image array
    integer nframe, nf2, i, j
    integer input(3, ihpixf,jvpixf)
    integer Colred(3)
    real mag
    do nframe = 1, 1
        nf2 = int (mag)
        call mkbitmap(rgb,nf2, input)
        call pixout(rgb,nf2)
    enddo
    end subroutine pixelout
    subroutine mkbitmap(rgb,nframe, input)
    implicit none
    integer nframe
    character*1 rgb(3,ihpixf,jvpixf) !      RGB pixel data array
    ! local
    real*8  red, gre, blu
    integer ired, igre, iblu
    real*8  ofst
    parameter(ofst = 0.7D+00)
    integer i, j, itmp
    real*8   aa, bb, cc, rr, xx, yy, tt
    integer ichoice
    parameter(ichoice = 0) ! .... choice
    real*8  pi
    parameter(pi = 3.14159265358979D+00)
    if (ichoice .EQ. 0) then
        do 100 j = 1, jvpixf
            do 100 i = 1, ihpixf
                rgb(1,i,j) = char(input(1,i,j)) ! red
                rgb(2,i,j) = char(input(2,i,j)) ! green
                rgb(3,i,j) = char(input(3,i,j)) ! blue
100     continue
    endif
    return
    end subroutine mkbitmap
    ! end of this file, thank you.
    end module
jimdempseyatthecove
I haven't tried your code. This seems like a regression error (bug) where the UDT%var as argument is seen as UDT alone.
Try: call RGBnode%fill(1,(RGBnode%nn))
The extra parenthesis will construct a copy of the member variable (unfortunate as it is, but removes the necessity for a user defined temp.
Jim Dempsey
JohnNichols
jimdempseyatthecove
John, et. al.
I must caution that that fix only applies to arguments that are intended to be changed/defined by the called procedure.
Jim Dempsey
JohnNichols
In pseudo-code
Module AA
TYPE A
INTEGER N(2)
End TYPE
FUNCTION START(N)
set N(2)
end function
FUNCTION USE(N)
USE N for work
end function
END Module AA
MAIN PROGRAM
TYPE A == set new
CALL A%Start(A%N)
!! A%N has now two integer values
CALL %Use((A%N))
!! Do not change it -- it was set in Start.
End main
This is how it is working at the moment, is that the intended use of the (())
JohnNichols
KMeans++ ResultKMeans++ Result
It has been fun to get the KMeans working in Intel Fortran and putting a drawing program with it, so I get straight plots.
cean
New Contributor II
Nice. Where I can get more information about these colors in rgb.f90? I want to make a color scale, from blue to red, 6~8 values in between. Thanks.
        case(1)                         !Medium Violet Red
            this%colors(i,1) = 199
            this%colors(i,2) = 21
            this%colors(i,3) = 133
            this%list(i) = "MVP"
JohnNichols
In the ZIP file are three solutions in Fortran.  They work on VS 2019 - but PSXE 2020.4.  I had to go back to get a working Fortran with the latest VS.
The KMEANS solution works on a simple set of FFT data.  The data is enclosed.
RGB.f90 is enclosed in the KM++ solution folder.  It has the 140 colors of the WEB Safe W3 coded into the routine.  You call a color by number.   ignore the RGB in the Kmeans it is an old version.
I enclose the web safe PDF that lists all the colors.  I have the subroutine set up for 140 colors, but only 70 have the full RGB codes in place. If you see Pink it is a place holder.   I have found it is much easier to stick to the color names in this list.
I include the code so you have samples of the calling routines.
This is not production code, it is for experimenting with data.
