29650 Discussions
Local Fortran variable changes mid process while calling C# DLL
MatchID_Ash
I have a C# dll which contains APIs to communicate with our company apps. I have created an additional static library in C++ CLI to consume these APIs through languages like native C++ and Fortran. The library works well with native C++ and most times with Fortran. However, some values change randomly over time in the Fortran code while running.  The values being exchanged are validated to be correct. The problem is with local Fortran variables. They change over course of execution.
jimdempseyatthecove
Try: __declspec(dllexport) extern "C" double GetValue(...
Jim Dempsey
jimdempseyatthecove
Jim Dempsey
jimdempseyatthecove
Also, Fortran does not support Structured Exception Handling. Thus the Fortran->C++ wrapper function should be compiled without SEH (though it can use SEH features).
Jim Dempsey
MatchID_Ash
Thank you Jim. The calling convention was the issue as you pointed out.
